Rob350 Posted January 14, 2017 Posted January 14, 2017 Iv got a ticky damper, the awkward one behind the plenum, I was just wondering if anyone had a little guide or just some tips when changing?? I'm sure I'll work it out but thought I'd ask before I run into any issues. I tried researching and could only find vids and guides for the easy damper to the side of the engine (drivers side) Cheers guys Quote
davey_83 Posted January 14, 2017 Posted January 14, 2017 I guess just remove parts until to gain access really. I'd pull the fuse for the fuel pumps and let the engine cut out, that'll remove the pressure from the system. Quote
Olly350z Posted January 14, 2017 Posted January 14, 2017 The one on the back of the engine is the easy one IMO. No connecting pipes and just two 10/12mm bolts. I personally found the plenum side one the most difficult due to the vacuum formed tubing. Be careful because you will leak fuel! Quote
