Wonky fuel door
Hey all :)
My fuel door isn't flush with the bodywork, the plastic seems to be fairly flimsy and has flattened out slightly over time rather than maintaining the same curvature as the panels. Has anybody else had this problem? Anybody aware of an aftermarket solution to fix it rather than buying an OEM flimsy replacement? :D
  On 09/01/2017 at 21:07, RobPhoboS said:
http://my350z.com/forum/maintenance-and-repair/377787-gas-door-fuel-door-fix.html
Try doing searches on here and the US forums, try it like this if you've not seen it before:
(copy and past this into google, change the bold to whatever you want)
site:my350z.com fuel door
site:350z-uk.com fuel door
Thank you =) I did search on here but am using tapatalk at the moment and the search seems fairly ineffective =)
  On 09/01/2017 at 21:40, veilside z said:
Apply gentle heat with a heat gun not to close to the paintwork and reshape whilst warm to perfection. This is if loosening the screws to adjust doesn't suffice. B) B) B)
Cheers dude, I will give both of these a whirl =)
