Millenium1 Posted January 9, 2017 Share Posted January 9, 2017 Hi all, I have found someone on here who has had the same issue that I'm having but there was no definitive answer to the problem, (I'm not being lazy I tried to find the answer). When I close my drivers door the driver side window comes down to just short of half way, I have tried raising the window, dropping the down and holding the switch then fully raising the window and holding the switch again to no avail. Any help in curing this issue would be greatly appreciated. Many Thanks for your time, Ricky Quote Link to comment Share on other sites More sharing options...
coldel Posted January 9, 2017 Share Posted January 9, 2017 I *think* you will need a window motor reset - vaguely remember something about this, taking the card of and manually intervening. Have a search through for window reset procedure otherwise a more knowledgable person will be along shortly I am sure... 1 Quote Link to comment Share on other sites More sharing options...
Rob332 Posted January 10, 2017 Share Posted January 10, 2017 Hi Ricky, As above, if a reset using the window switch itself does not work, then there is a small black reset button directly on the motor itself. http://www.powerwin.com.au/mechanicscorner/Nissan%20Reset%20Procedure.pdf The door card will need to come off, and I'm pretty sure there is a guide on how to do this in the guides section. The button on the motor will be hidden behind a circular piece of black tape. Just pull this off and you should see it Hope this helps. 1 Quote Link to comment Share on other sites More sharing options...
Millenium1 Posted January 10, 2017 Author Share Posted January 10, 2017 I *think* you will need a window motor reset - vaguely remember something about this, taking the card of and manually intervening. Have a search through for window reset procedure otherwise a more knowledgable person will be along shortly I am sure... Thank you for your input much appreciated Quote Link to comment Share on other sites More sharing options...
Millenium1 Posted January 10, 2017 Author Share Posted January 10, 2017 Hi Ricky, As above, if a reset using the window switch itself does not work, then there is a small black reset button directly on the motor itself. http://www.powerwin....t Procedure.pdf The door card will need to come off, and I'm pretty sure there is a guide on how to do this in the guides section. The button on the motor will be hidden behind a circular piece of black tape. Just pull this off and you should see it Hope this helps. That's fantastic thank you Rob Quote Link to comment Share on other sites More sharing options...
shieldsie Posted June 19, 2017 Share Posted June 19, 2017 Hi all. I cant find how to remove the door card in the guides section. Help please. Quote Link to comment Share on other sites More sharing options...
