taybo Posted January 5, 2017 Share Posted January 5, 2017 (edited) Having my BC coilovers, sway bars, Adjustable camber and toe arms fitted at the garage today. Mechanic had a few problems as he is not familiar with the zed set up. I think I have cocked up on ordering toe arms as they won't fit with the rear coilovers. Is this correct? A= camber arm B= Toe arm Also can anyone ID this bush as it needs replacing? Many thanks in advance Edited January 5, 2017 by taybo Quote Link to comment Share on other sites More sharing options...
lmc Posted January 5, 2017 Share Posted January 5, 2017 Depends if you have true coilovers or separate spring and damper on the back. If the latter then no you don't need them. Quote Link to comment Share on other sites More sharing options...
taybo Posted January 5, 2017 Author Share Posted January 5, 2017 Depends if you have true coilovers or separate spring and damper on the back. If the latter then no you don't need them. I have just bought BC Racing coilovers with the separate spring! Quote Link to comment Share on other sites More sharing options...
lmc Posted January 5, 2017 Share Posted January 5, 2017 Depends if you have true coilovers or separate spring and damper on the back. If the latter then no you don't need them. I have just bought BC Racing coilovers with the separate spring! What brand are the toe arms? Quote Link to comment Share on other sites More sharing options...
taybo Posted January 5, 2017 Author Share Posted January 5, 2017 Megan Racing Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted January 5, 2017 Share Posted January 5, 2017 Banana arm bushing has failed there on the front (compression arm/rod). I have a couple of different poly ones for sale if interested. 1 Quote Link to comment Share on other sites More sharing options...
