Drivers side door locking intermittent
euphio
Hey all,
Recently when locking my car i noticed that although i could audibly hear it locking, the indicators were not flashing. After checking out the status of the car I realised that the drivers door was still unlocked but the car alarmed.
Using both the key and the switch on the drivers door, the passenger side lock flips but the drivers doesn't, audibly it sounds as if everything is trying to lock. I can open/close the lock manually or by key with no problems.
The issue appears to be somewhat intermittent at the moment.
I was wondering if anyone has experienced this issue too / could point to the likely cause.
Edited by euphio
Had a locking issue this morning, the driver side wouldn't unlock, after the car warmed up for a few minutes it was fine. Have you tried the button on the driver side that does the central locking as well? Does the physical switch on the inside of the door work?
