370z auto g/box fluid
beemerkev
On the side of the gearbox, you will need some kind of pump to get it in there , you need to run the gearbox up to temperature and only use the correct fluid which isnt cheap nor widely available
thanks for replies fellas
guessin I lost maybe 0.5l when startin engine with g/box cooler pipes uncoupled!!
didn't think that small amount would cause any probs but when trying to reverse car moves v slowly
before goin down pump/ramp route ive got access to oil cooler so will try to get fluid dribbled in thro cooler pipe tomoro
cheers Kev
