135,000 miles, what preventative engine maintenance/replacements parts?
blindbandit
My zeds getting high in the miles and I the next 10,000 will be the hardest yet as it's getting tracked and drifted. It's had a good service history and I've just replaced diff, gear box and engine oil and filters.
My question is to you guys that know this engine well, what engine components should I look at replacing/upgrading or maintenance should I carry out to stave off bhp loss.
Any top tips much appreciated
Do not waste your time or money on compression tests or timing chain chain replacement.
The best preventative measures in this instance is to use a good quality engine oil and service regularly, together with very regular dip stick checks on the engine oil level.
At 135k miles there is bound to be wear and tear present, so chains and low compression issues should only be dealt with as and when they happen, which might be never.
However, if the engine eventually does go pop, then just drop in a known pre-owned engine from a known and reputable seller.
