scotzman Posted December 24, 2016 Share Posted December 24, 2016 Hi all, have new and front bumper i want painted and fitted and received the quote below... any opinions on if thats expensive/reasonable/cheap ? We charge £35 + VAT per hour so you're looking 3-4 hours per bumper I would guess, but again it depends on the bumpers. To paint the panel is £250 + VAT per panel as they are new parts. When you come in Monday ask for a 10% discount and we will honour that in the estimate straight away. Thanks for any advice Quote Link to comment Share on other sites More sharing options...
Miller350z Posted December 24, 2016 Share Posted December 24, 2016 Well mate I got my nismo kit sprayed and fitted and the rear bumper, bonnet and boot sprayed for £900 for comparison. I thought it was a good price. The paint is spot on but I would've preferred them to spend a little more time prepping fitment before spraying. Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 24, 2016 Share Posted December 24, 2016 Looks about average, but if its a fiberglass bumper, expect more time to obtain correct fitment, as they can be a real pain to get spot on. Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted December 24, 2016 Share Posted December 24, 2016 (edited) I received the quote the estimate Two completely different things, they have given you an estimate, not a quote. As Tricky says above, until they have the car and bumper and know what they are up against, expect the price to change, unless its oem which should be fairly straightforward to give you a proper quote. i.e i was quoted £350 to fit and paint a rt performance bumper by my usual trustworthy sprayer, once they saw the issues needed to get correct fitment, that went up to £550. Sorry but you are kind of asking, how long is a piece of string because of the unknown quantities P.s No mention of material costs in there (paint, masking tape and other things required). Edited December 24, 2016 by Jetpilot Quote Link to comment Share on other sites More sharing options...
scotzman Posted December 24, 2016 Author Share Posted December 24, 2016 Hi, it was just a question on peoples thoughts, due my quotable inexperience, i was just asking if the prices were reasonable and i know the prices could be adjusted either way. Quote Link to comment Share on other sites More sharing options...
scotzman Posted December 24, 2016 Author Share Posted December 24, 2016 Well mate I got my nismo kit sprayed and fitted and the rear bumper, bonnet and boot sprayed for £900 for comparison. I thought it was a good price. The paint is spot on but I would've preferred them to spend a little more time prepping fitment before spraying. Sent from my SM-G930F using Tapatalk Thanks Miller, sort of puts in in perspective... Quote Link to comment Share on other sites More sharing options...
Miller350z Posted December 24, 2016 Share Posted December 24, 2016 No problem mate, I think if it's a straight forward spray the front bumper £250-£300 is what you should be looking at however the price will increase if it's aftermarket bad fitting like has been said. I had a kit I took to 3 places and none of them would touch it it was that far out. I then bought another from Rt and they said that was much better quality which it was and they had no problem doing it. I am a bit of a perfectionist though and in hindsight maybe should've test fitted it and done some of the prep myself as I feel I got the job done cheap, not as much money was spent on prep. For example I have a panel gap or about 2mm along one part but then the last inch the gap drops to about half a mill. Only noticeable close up but you really need to know the quality of finish you are after and make sure the price reflects the work Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
scotzman Posted December 24, 2016 Author Share Posted December 24, 2016 No problem mate, I think if it's a straight forward spray the front bumper £250-£300 is what you should be looking at however the price will increase if it's aftermarket bad fitting like has been said. I had a kit I took to 3 places and none of them would touch it it was that far out. I then bought another from Rt and they said that was much better quality which it was and they had no problem doing it. I am a bit of a perfectionist though and in hindsight maybe should've test fitted it and done some of the prep myself as I feel I got the job done cheap, not as much money was spent on prep. For example I have a panel gap or about 2mm along one part but then the last inch the gap drops to about half a mill. Only noticeable close up but you really need to know the quality of finish you are after and make sure the price reflects the work Sent from my SM-G930F using Tapatalk Thanks Miller, Ive fitted the front and it goes in on the 9th jan, looks a pretty good line up and that was a quick fitting and only stuck on with the top of the bumper clips so ill fine tune it so to speak before then, the rear bumper is a chargespeed so im guessing that might be a little more difficult to do myself as i dont know about brackets etc so a little reluctant to mess with that. Quote Link to comment Share on other sites More sharing options...
Exec Posted December 24, 2016 Share Posted December 24, 2016 (edited) My job involves getting damaged cars repaired. For a full bumper respray I would expect £200 + vat North West UK, however this would be oem fitted just to repair. As others have said aftermarket fiberglass would be a pain to fit. Offer cash, may get you it a bit cheaper! Edited December 24, 2016 by Exec Quote Link to comment Share on other sites More sharing options...
scotzman Posted December 25, 2016 Author Share Posted December 25, 2016 My job involves getting damaged cars repaired. For a full bumper respray I would expect £200 + vat North West UK, however this would be oem fitted just to repair. As others have said aftermarket fiberglass would be a pain to fit. Offer cash, may get you it a bit cheaper! Or test drive when done, then do a runner. Quote Link to comment Share on other sites More sharing options...
Ricey Posted December 25, 2016 Share Posted December 25, 2016 My job involves getting damaged cars repaired. For a full bumper respray I would expect £200 + vat North West UK, however this would be oem fitted just to repair. As others have said aftermarket fiberglass would be a pain to fit. Offer cash, may get you it a bit cheaper! About right id say Sent from my SM-G925F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Payco Posted December 25, 2016 Share Posted December 25, 2016 (edited) Agree with all the above but as others have said the finish is key.No point getting a good paint job if the fitment is not good.I would make sure they have some practical experience of fettling fibre glass too. Edited December 25, 2016 by Payco Quote Link to comment Share on other sites More sharing options...
