upping 35 to 40's on the back ok?
greasyphil
Your current F/R difference is 3%, if you upped it to 40 profile tyres on the rear it would be 7%, which is quite a jump. However, to the TCS it would appear the rear is rotating slower due to the larger rolling radius, so I am unsure how the TCS would react to that.
The height of the sidewall profile * tyre width profile is given as a percentage, so 235/40 means the sidewall will be 235 * 0.4).
You'll need to calculate the difference that you're going to create from standard, and find out what the tolerance of the TCS is to determine if you'll cause issues.
This might help:
http://www.willtheyfit.com/#isPage=1
