RickyZ Posted December 12, 2016 Share Posted December 12, 2016 So the other day I was driving home from work and the exhaust note changed and didn't sound too good. I took my car to my local garage today and they have advised that the engine is hesitating under load so they have taken a temperature test of the catalytic converters and one has gone. Bank 2 was too low to be effective and bank 1 was fine. They recommend they should be changed and do both at the same time. The bad news is that they can only order the parts from Nissan main dealer and they will be over £2k for everything. They also said the lambda sensors may need to be replaced if they can't remove them from the original cats so have included them in the quote. The parts are - Near side catalytic converter Off side catalytic converter Manifold lambda sensor Offside rear lambda sensor Near side rear lambda sensor Down pipe to catalytic converter gasket Catalytic converter to centre exhaust gasket I have always supplied my own parts before so they said if I can source them it'll just be £80 labour to fit. So what do people think would be best, Oem cats or maybe changing to high flow cats? Can anyone confirm whether I'll need the sensors too? Just want the car back to full health but for the best price. Quote Link to comment Share on other sites More sharing options...
Ekona Posted December 12, 2016 Share Posted December 12, 2016 Second hand set of OEM would be my choice, if one has indeed gone. Also I'd only replace the one, no need to do both. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted December 12, 2016 Share Posted December 12, 2016 What's best is to replace the damaged/broken/faulty CAT but it's up to you how you do it. Is the rest of your exhaust system standard? What's the condition like & do you ever intend to change it for a s/s exhaust system? As I like modifying my cars I would take this as the perfect excuse to upgrade to some HFC's and possibly do the full exhaust system whilst I was at it. Obviously that would depend though on funds available and whether or not you want to keep the car for a good while or even want to modify it at all. If you were/are perfectly happy with how it is/was then Dan's suggestion will be by far the cheapest easiest option with zmanalex or Emperor Tuning on here probably being able to help you out with some used OEM Cats. The sensors may or may not need replacing and I'd probably replace the Cats first so that I could see afterwards what the sensors are doing. E.g. Whether they throw up a fault code. Quote Link to comment Share on other sites More sharing options...
RickyZ Posted December 12, 2016 Author Share Posted December 12, 2016 I have a cobra resonated exhaust at the mo. Just the back though so cats an y pipe are Oem. I'm thinking of selling next year anyway so don't need to upgrade, just needs to be fixed adequately. Was just toying up hfc if they are reasonable compared to Oem replacement. I'll pm Alex. Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted December 13, 2016 Share Posted December 13, 2016 2nd-hand is a no-brainer! Quote Link to comment Share on other sites More sharing options...
GMballistic Posted December 13, 2016 Share Posted December 13, 2016 2nd-hand is a no-brainer! From what you've said RickyZ then this above is your best option as Toon Chris says. Quote Link to comment Share on other sites More sharing options...
G1en Posted December 13, 2016 Share Posted December 13, 2016 If your anywhere near West Yorkshire i have 2 cats in garage just taken off my 08HR 65k miles in average nic you can have cheap Quote Link to comment Share on other sites More sharing options...
RickyZ Posted December 14, 2016 Author Share Posted December 14, 2016 If your anywhere near West Yorkshire i have 2 cats in garage just taken off my 08HR 65k miles in average nic you can have cheap Thanks but my car is DE rev up so wont fit, also down south too Quote Link to comment Share on other sites More sharing options...
