scotzman Posted December 11, 2016 Posted December 11, 2016 Hi All, Anyone know if there is a knack to securing the bottom rubber mounts on the frame for the 2 pins on the radiator to slot into, there is a hole either side but the rubber mounts seem to be too big to fit, tried to put them in from the top and bottom of the lower frame, the rubbers seems hard, would that be the case. Any help would be much appreciated Quote
GMballistic Posted December 11, 2016 Posted December 11, 2016 Moved to the more appropriate area. Please don't make anymore on the same topic thanks. Good luck. Quote
