Randy_Baton Posted November 29, 2016 Share Posted November 29, 2016 If I have an outside light already installed in my garden, is there a way to take out the bulb and wire in a set of outdoor fairy lights into the light socket somehow? Quote Link to comment Share on other sites More sharing options...
Strudul Posted November 29, 2016 Share Posted November 29, 2016 Don't see why not, but you'll have to check the current / voltage and it may require a resistor. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 29, 2016 Share Posted November 29, 2016 I am not a sparky however I have the annual task of sorting out 800 external low voltage lights every Xmas. I run each set of 200 via independent transformers. I would probably avoid tapping into the outside light as your transformer "if required) would be outside. If it was me I would probably hook my transformer up to an inside socket and run some low voltage wires to your fairy lights, providing they are not a hundred miles away. Please do not sue me if you electrocute yourself. Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted November 29, 2016 Author Share Posted November 29, 2016 The lights inside a fairly big case, so I'm not to worried about the connection being outside. I just wasn't sure how to actually wire it in. I was hoping there might be some form of bayonet adapter, but apparently they are illegal. I'm only talking a couple of meters of lights. Your probably right though, I should see if the back doors got enough room to fit some wires under it so I can plug it into the socket by the door. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 29, 2016 Share Posted November 29, 2016 On 29/11/2016 at 16:57, Randy_Baton said: I was hoping there might be some form of bayonet adapter, but apparently they are illegal. And that is because there is NO earth, which can be life threatening. Quote Link to comment Share on other sites More sharing options...
Ponsonby Posted November 30, 2016 Share Posted November 30, 2016 On 29/11/2016 at 16:57, Randy_Baton said: The lights inside a fairly big case, so I'm not to worried about the connection being outside. I just wasn't sure how to actually wire it in. I was hoping there might be some form of bayonet adapter, but apparently they are illegal. I'm only talking a couple of meters of lights. Your probably right though, I should see if the back doors got enough room to fit some wires under it so I can plug it into the socket by the door. If the lights are 12V and running from a transformer the wire will be very thin. It will probably pass through the seal of a door or window, I would pick one that is not going to be used since opening and closing will probably break the wire after a while - if it does break then no drama's, it is only 12V. The transformers are usually cheap and nasty and not suitable to be located outside. Don't go bodging your outside light, not worth the risk. Quote Link to comment Share on other sites More sharing options...
