Check engine light has come on
dbass
Hi,
The check engine light on my 350z has come on, it's not flashing, just constantly on. The car is modified but that was all done a while back. The car seems to be running ok. Has anyone else had experience with this? Is it ok to continue to drive it? What do you think? Thanks :)
try this mate
Please read all instructions and be familiar with them before any attempts.
A stop watch or an analog clock with a second?s needle will be useful.
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch ?ON? and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to ?OFF? position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
if its running ok and not missing or running rough then its probably just a blip and should be fine for now. If you google it mate you`ll find all sorts of info and should give you peace of mind
this sort of thing
http://www.simple-ca...gen-Sensor.html
you do need to get it sorted and not leave it
Edited by gsexr
If the ecu is showing up O2 sensor fault I'd clear it and leave it if everything is fine and it doesn't light up again.
Both times mine lit up it was the same thing.
The first time I went to the garage to double check.
They just relieved me of £25 to hook it up to their code reader and tell me they'd reset the ecu and if everything is fine to leave it :lol:
if i`m reading that right it look`s like
P1147 Heated O2 Sensor 2
P1167 Heated O2 Sensor 2
perhaps someone can confirm that
Great thanks
I had the same 2 messages just 2 days ago when it was minus 5 outside, just cleared the codes and all is fine, only the second time its happened.
Just put it down to a minor blip in the system because the car is running sweet as ever.
Full cobra exhaust with cobra HFC's, plenum spacer, K&n panel filter. No remap.
