Rear Camber - Advice/Knowledge Needed (Current Alignment Provided)
Lewis_UK
Good evening Ladies and Gents,
So after reading this thread: http://www.350z-uk.com/topic/112747-advice-on-parts-needed/page__hl__camber
I decided to get alignment done, I knew it was out, but blimey...
Before:
Front:
Camber: Left Front -1.06' | -0.53' Right Front
Toe: Left Front -0.27' | 0.17' Right Front
Total Toe: -0.10'
Steer Ahead: -0.22
Rear:
Camber: Left Rear -2.59' | -4.33' Right Rear
T oe: Left Rear -0.05' | 0.23' Right Rear
Total Toe: 0.18'
Thrust Angle: -0.14'
After:
Front:
Camber: Left Front -1.14' | -0.51' Right Front
Toe: Left Front 0.02' | 0.02' Right Front
Total Toe: 0.04'
Steer Ahead: 0.00'
Rear:
Camber: Left Rear -2.57' | -4.33' Right Rear
Toe: Left Rear 0.01' | 0.09' Right Rear
Total Toe: 0.10'
Thrust Angle: -0.04'
They kind of sorted the front but basically the rear camber bolts are siezed and didn't want to attempt incase of snapping the bolts. So only got charged for front adjustment.
Now I have some questions, from what I've been reading you can't really adjust the rear camber, but generally if you lower the suspension.
But to be nearly -4.33' on the right rear? Ontop of that, all of my suspension looks completely stock, I do want to stay stock with abit of camber.
What are my options from here, I mean, if I buy new bolts can I get them adjusted to maybe -2.00', -2.50' with OEM rear camber arms?
The thread I linked above just generally states get adjustable ones, but surely if from what I can tell if the camber arms, springs and suspension are OEM, if I just get new bolts then I can get it adjusted properly?
Many thanks in advance.
