leigh_boy Posted November 20, 2016 Share Posted November 20, 2016 (edited) . Edited December 12, 2016 by leigh_boy Quote Link to comment Share on other sites More sharing options...
leigh_boy Posted November 20, 2016 Author Share Posted November 20, 2016 (edited) . Edited December 12, 2016 by leigh_boy Quote Link to comment Share on other sites More sharing options...
Ekona Posted November 20, 2016 Share Posted November 20, 2016 Glad to be of assistance Quote Link to comment Share on other sites More sharing options...
leigh_boy Posted November 21, 2016 Author Share Posted November 21, 2016 (edited) . Edited December 12, 2016 by leigh_boy Quote Link to comment Share on other sites More sharing options...
leigh_boy Posted November 22, 2016 Author Share Posted November 22, 2016 (edited) . Edited December 12, 2016 by leigh_boy Quote Link to comment Share on other sites More sharing options...
karlh Posted November 22, 2016 Share Posted November 22, 2016 any know what controls the fans? The fans are controlled by two relays on the IPDM E/R, located by the battery. Both fans run together, either at low speed or high speed. The ECU signals fan operation over the CAN bus based on several parameters. These include vehicle speed, coolant temperature, air conditioner on or off, air conditioner refrigerant pressure, and engine running status. If the air conditioning is on and the refrigerant pressure is high, the fans run at high speed regardless of coolant temperature or vehicle speed. If the pressure is a bit lower the fans may be off or run at low or high speed, depending on coolant temperature or vehicle speed. If the air conditioning is off the fans should run at low speed when the coolant temperature reaches 98C, and at high speed when the coolant reaches 100C. Quote Link to comment Share on other sites More sharing options...
