Black 350 HR
jimmy1280
I actually used hammerite satin finish from a spray can. I've done a few interior plastics before so had a bit of practice.
You could always take the bits to a paint shop once the lights apart and get them to do the spraying if you don't fancy a diy. Only thing is it's quite time consuming so if you use the Z as a daily that could be an issue.
