Buying Wrap...
BenjaminKirk
don't think Ebay is the best place as you can get some poor quality stuff from there
I would look for 3M or Avery Dennison distributors
I used MDP supplies in the past for their air release car vinyl (as an option)
Avery is really good, 3M also. Most good companies use either. It is pricey though once you go for larger sizes.
Do practice on small things first, it does look so easy on videos etc but it is an acquired skill to do it properly. Also ensure you do the prep first, any tiny particle of dirt under the wrap will stick through and not give a smooth finish.
You can also get some really good quality stuff on there if you just do your research. Lots of the suppliers have eBay shops aswell.
eBay shop - CarcarStyleLimited does 3M film: http://stores.ebay.co.uk/CarcarStyleLimited
I bought some Carbon fibre wrap to make up some fake Nismo B-pillar trims, which turned out well: http://www.ebay.co.uk/itm/381348034768
Dan is correct, buy plenty. I spent ages on the first pillar trying to smooth out the creases with a heat gun.
When I ripped off the first attempt in desperation, I found the wrap actually had an outer protective film, and I was trying to smooth out that. :lol:
  • Like 4
Excellent thanks.
I've sent him a message
