Garage lighting & heating
-G-
So I recently moved house with the better half & part of the deal was building a garage, which is currently under construction. The size is going to be 7.5m x 6m x 2.1m so around about 90 m3 in volume (accounting for walls) and about 45m2 floor space. We have an electrician ready to install a distribution board in the garage once its built, but I'm still humming and heying about the lighting & heating & also Frost protection I should have installed. The garage will be detached and away from the main house.
Has anyone built a garage before & can share any nuggets of wisdom on what to avoid or otherwise embrace? I'm not going to be routing water into the garage so anything I install needs to be electrical - I've been thinking convector heaters or Infra-red heaters (how do they affect car paint? I assume they don't??) - I'm really not sure what to opt for.
Thanks in advance. :)
Edited by -G-
Personally I would install an electric underfloor heating mat more for control, I.e can set temp/timer for frost protection etc and then some additional space heater if you want to get it toasty and work in there, you would need to tile over however, but no big deal and makes it more plush.
Edited by Jetpilot
You can never have too many lights in a garage.
Don't use downlighters as they don't offer enough light.
Separate your lights into 2 or 3 separate switches so you can vary the amount of light you have in there. As you won't always need (or want) the full Blackpool Illuminations.
Put double sockets everywhere. I have 14 sockets in mine and still get frustrated when needing to use an extension
Yep , sockets are key you can never have enough , i have 4 tubes in my double garage and use a work lamp when i'm doing stuff on the car , the tubes are really good when detailing as the show the swirls etc
Heating , a fan heater will do it , i have two double rads in my garage but they are set for frost protection only , a small fan heater provides enough heat for me if im working in there with the door shut
