nissanman312 Posted November 9, 2016 Share Posted November 9, 2016 (edited) I have my old sibon bonnet back I bought it back for pennies compared to new price as a little project for winter. Somthing to tinker with So I'm after a bit of advice The bonnet is fiberglass based and is scuffed and has a couple of holes in. Im thinking fiberglass and resin is going to be be the best way to repair the holes and then filler on the finer scuffs ?? Obviously once repaired I will get it sprayed to the color of the car and use it again once supercharged Pictures here to give you an idea of damage and help you advise tia Edited November 9, 2016 by nissanman312 Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted November 10, 2016 Share Posted November 10, 2016 if you are going to spray it, then you might find the best source to repair it from looking at marine stuff, you can get some pretty cool epoxy resins and fillers that would prob do the job - check out you tube for boat hull repairs. then just prep the whole thing for spraying. 1 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 10, 2016 Share Posted November 10, 2016 Grind it back until all the damage is revealed and then use some matt and resin, and finish of with a filler, flat all over with 240grit and prime with a filler primer. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted November 10, 2016 Share Posted November 10, 2016 As above, cut it back and patch with FG matt and resin, filler,flat,prime,paint and lacquer. Job Done: Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted November 10, 2016 Author Share Posted November 10, 2016 Thanks guys I shall have a bash when I get a free weekend Quote Link to comment Share on other sites More sharing options...
