GeorgeB Posted November 8, 2016 Share Posted November 8, 2016 Hopefully you guys can access this link. https://goo.gl/photos/CfDfkMoUXuVu1QFc9 I sometimes hear this sound when I turn the ignition on, before the engine is started. Not the sound coming from the gauges, but the du du du du du type sound! It doesn't happen every time I turn the ignition on and it always stops after a few seconds. Can anyone confirm if this is the fuel pump priming? Could it be anything else? Assuming it is the fuel pump, what do I need to do about it? Thanks! George Quote Link to comment Share on other sites More sharing options...
Gassy Posted November 8, 2016 Share Posted November 8, 2016 Hi George,to me I doesn't sound like fuel pump,you may be able to narrow it down as the pump is located behind the passenger seat underneath the glove box(easy to get to) just get you close and get somebody to put the ignition on and see if the noise comes from that area.Or does the noise come more from under the bonnet if so it could be the fuel pressure regulator?. Please note I could be wrong it could be something completely different. On a lighter note it sounds like an alien í ½í±½ getting excited to be going for a drive in your Zed. Quote Link to comment Share on other sites More sharing options...
TT350 Posted November 8, 2016 Share Posted November 8, 2016 Pump is usually a brief whine/buzz while it primes. Mines a walbro 255lph and it's always more audible than the standard one was. Especially when running low. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted November 8, 2016 Share Posted November 8, 2016 More to the point what's that doing out in this weather Quote Link to comment Share on other sites More sharing options...
GeorgeB Posted November 10, 2016 Author Share Posted November 10, 2016 lol, don't worry mate, it hasn't moved for ages! I don't *think* the sounds comes from behind the passenger seat. I'll have to check next time it happens, always fun when things are intermittent! Quote Link to comment Share on other sites More sharing options...
evilscorp Posted November 10, 2016 Share Posted November 10, 2016 Isn't the fuel pump behind the drivers seat? Been a while since I changed mine. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted November 10, 2016 Share Posted November 10, 2016 Isn't the fuel pump behind the drivers seat? Been a while since I changed mine. Pretty sure it is Yeah Quote Link to comment Share on other sites More sharing options...
