Quick Question
Willsy1980
when i done my Gbox Fluid change i used Genuine Nissan Gearbox oil and molysip additive . After some research i found out that it helps with smoother gear changes .Clark Motorsport supplied everything next working day give them a shout .
I did my oils the other week KyleR and yes I added Molyslip exactly the same as the one in the pic above.The fill plug is on the offside/drivers side of the box and you will need a 10mm Allen key to remove the plug.
Perfect timing, my car is going for a service soon ish, only changed ALL the fluids about 3500 miles ago ( This January ) would it be okay to just add the molyslip rather than change the oil too?
Sorry for thread highjacking!
yes
