Keyser Posted November 5, 2016 Share Posted November 5, 2016 So here I am searching round ebay for an LED light solution for a little project and I came across this, I think I am less sure of what it is after reading the description Enjoy - Description: Main Features: In the rain and fog weather, dust storms can drive farther and more efficiently with caution in order to avoid too close to the rear of the vehicle causing the accident, was driving at night to provide a more eye-catching vehicle Location warning and steering instructions, also a novice car reversing against bit auxiliary line storage. 100% brand new and high quality This is the newest car laser light, it can offer a safety distance between your follow cars in rain and fog weather, you can adjust the angle of the bulb to adjust the safe distance and avoid the traffic accident Waterproof, shockproof, anti-fog & sun-proof design Low power consumption and ultra long life Easy to install, simply to replace, convenient using Compatible with: Fit all kind of vehicle with 12-24V working voltage Specification: The maximum adjustable angle: up & down ±90° Waterproof grade: IPX4 Light Color: Red (650nm) Laser Power:200mw Working temperature: -20℃ to 70 ℃. Working voltage: 12V-24V Safety: classⅢB The maximum adjustable angle: up & down ±90° Size:2.4 x 1.7cm/0.94"x0.67"(approx) Quantity:1 set (as picture show) Installation: Connect to License Plate Light Line ( Recommend ), you can connect to the brake light line, rear fog light line, and warning light line as well Stick the 3M above the middle of the licence plate Use the screw to fix the light, and adjust the suitable angle to get the safety distance you want. Then the installation is ok Note: Don't irradiate the eyes when the installation Don't block the plate mounting position The product is only used on voltage 12~24V car, sedan Due to the difference between different monitors, the picture may not reflect the actual color of the item. Thanks for your understanding If you need to see the pic here is the link http://www.ebay.co.u...v0AAOSwmrlUwLLr Keyser Quote Link to comment Share on other sites More sharing options...
Andy_Muxlow Posted November 5, 2016 Share Posted November 5, 2016 😂 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
ZEUS Posted November 5, 2016 Share Posted November 5, 2016 Seems perfect if you want a solution to fog weather, dust storms or a more eye catching vehicle location and steering instruction, can't see the problem Quote Link to comment Share on other sites More sharing options...
TT350 Posted November 6, 2016 Share Posted November 6, 2016 Looks like the language translater was working overtime! Quote Link to comment Share on other sites More sharing options...
glrnet Posted November 6, 2016 Share Posted November 6, 2016 You are sooooooooo picky!! 1 Quote Link to comment Share on other sites More sharing options...
