350Z paradise Posted November 2, 2016 Share Posted November 2, 2016 Hi all..after a spirited drive Worcester to Leeds round trip this evening,when accelerating hard ESP & skiddy car symbol come on & stay on,along with intermittent handbrake symbol. After restarting engine they clear...but come on again when accelerating hard. Any ideas guys/gals ?? Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted November 2, 2016 Share Posted November 2, 2016 Have you recently changed tires? If so, what sizes did you fit (rear needs to be about 1% to 3% larger in diameter)? If not the tires, then maybe a wheel speed (ABS) sensor, curious that it happens only after driving hard though. 1 Quote Link to comment Share on other sites More sharing options...
veeg33 Posted November 3, 2016 Share Posted November 3, 2016 Could be a number of things........^^ as above, or brake fluid needs topping up, or ABS actuator, etc,etc. Best is to get a code reader to get the code. 1 Quote Link to comment Share on other sites More sharing options...
350Z paradise Posted November 3, 2016 Author Share Posted November 3, 2016 Thanks veeg33...it was low brake fluid...topped up,booted it a few times..NO SYMBOLS on dash..Happy days again. 1 Quote Link to comment Share on other sites More sharing options...
veeg33 Posted November 3, 2016 Share Posted November 3, 2016 Glad this is as simple as topping up brake fluid. 1 Quote Link to comment Share on other sites More sharing options...
josh2005 Posted November 25, 2016 Share Posted November 25, 2016 Apologies to bump this! I've had the same happen to mine lately but I don't think it is brake fluid low as only 2 days ago had a brake fluid change so can't see it being low! Quote Link to comment Share on other sites More sharing options...
Richf Posted November 25, 2016 Share Posted November 25, 2016 Apologies to bump this! I've had the same happen to mine lately but I don't think it is brake fluid low as only 2 days ago had a brake fluid change so can't see it being low! Check it NOW! . it could be low they might not have tightened a bleed nipple correctly Quote Link to comment Share on other sites More sharing options...
josh2005 Posted December 4, 2016 Share Posted December 4, 2016 Apologies for bumping this! Finally got my car to the garage, they checked the Brake fluid and it was on maximum, their computer is throwing up a fault with the abs speed sensor on one of the front wheels however he's saying the signal looks right? Is the obvious fix to replace the abs sensor? Not long before the service I had my winter wheels fitted so possibly been damaged in the switchover? Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted December 5, 2016 Share Posted December 5, 2016 (edited) Yeh, abs sensor common cause of this problem, change it. By the way, it's not surprising that the computer says the signal is alright. ABS sensors usually go progressively. Edited December 5, 2016 by Aashenfox Quote Link to comment Share on other sites More sharing options...
josh2005 Posted December 17, 2016 Share Posted December 17, 2016 Replaced the abs sensor and the lights still come on after driving it for 5 minutes ish! Any more ideas? Quote Link to comment Share on other sites More sharing options...
-G- Posted December 17, 2016 Share Posted December 17, 2016 Top tip, perform an emergency stop in the car and make sure the ABS kicks in. The ABS sensor in my old celica was replaced but the fault light persisted. One emergency stop later it cleared. Quote Link to comment Share on other sites More sharing options...
josh2005 Posted December 17, 2016 Share Posted December 17, 2016 Abs kicks in within the first few mins of driving but not tried it with the light on though, will still give it a go! Quote Link to comment Share on other sites More sharing options...
josh2005 Posted December 18, 2016 Share Posted December 18, 2016 Had a go and the abs doesn't seem to kick in, traction control definitely doesn't! Lights still on too! Think I'll have to try another garage! Quote Link to comment Share on other sites More sharing options...
-G- Posted December 18, 2016 Share Posted December 18, 2016 Yeah, that's a big issue like, need to get those solenoids firing or else your insurance won't pay out over any accidents you have. I also had issues with a wheel bearing that made my ABS kick in whenever I was slowing to a halt. Worth looking at also. Quote Link to comment Share on other sites More sharing options...
josh2005 Posted January 3, 2017 Share Posted January 3, 2017 Had it re-plugged in today and it looks like the sensor again so guessing a rubbish sensor been used as the replacement! Going to buy a better one then try that! Quote Link to comment Share on other sites More sharing options...
350Z paradise Posted January 3, 2017 Author Share Posted January 3, 2017 Hey Josh,good luck,sorry to hear it wasn't a simple fix like mine w/brake fluid Quote Link to comment Share on other sites More sharing options...
