Gear Issues
Strudul
Maybe completely unconnected, but given the gear selection difficulty just maybe the 'gate' under the gearlever is not quite correctly located - I had this issue once on the 370.
This is definitely worth a look. I heard (on the forum) that this can affect 5th/6th gear selection at least. If the box has been out then it seem a likely place to at least have a fiddle.
Doesn't sound like it will help with 2nd though :(
Would it be obvious if it wasn't located correctly? And how do you go about checking?
Here you go: http://www.350z-uk.c...-the-gear-gate/
Cheers.
However, thinking about it, can I discount this as a possibility since when I'm stationary (engine off or idling) it's silky smooth? If it was misaligned, then surely I'd have issues all the time, and it wouldn't be dependant on the revs?
Edited by Strudul
Cheers.
When I had the issue on the 370 it was fine when stationary, but at the time I persuaded the mechanic to drive it when he experienced the problem and then sorted it.
This was on the way home from the Nissan dealer who had changed the box under warranty - and so I guess they did not do a full road test :thumbdown:
Edited by Ebized
Interesting.
I don't know enough and I'm curious - can someone enlighten me as to why would it make any difference when the car is moving? What is changing that could cause it to be misaligned but only while moving?
:doh:
see points 7 & 8 in the link I posted @ number 26
I did, but maybe I'm not understanding...
Points 7 & 8 will make it all nice and aligned, but as the engine is off when it's aligned, won't it will be aligned for just that?
When I'm moving you say there will be some flex that causes everything to change position. As such, won't it will be back out of alignment when moving.
Or does following those steps align it with that in mind? I.e. has Nissan planned ahead and designed it so by lining it up with that notch it will be setup perfectly for when the car is moving etc. As such, will that mean it will be nice and smooth while driving, but trying to shift while stationary will be notchy (though obviously this is better than having it notchy while driving).
Am I on the right lines here?
Edited by Strudul
:doh:
Or does following those steps align it with that in mind? I.e. has Nissan planned ahead and designed it so by lining it up with that notch it will be setup perfectly for when they car is moving etc. As such, will that mean it will be nice and smooth while driving, but trying to shift while stationary will be notchy (though obviously this is better than having it notchy while driving).
THIS :thumbs:
