cascade88 Posted November 1, 2016 Share Posted November 1, 2016 Cleared out a locker and found some bits seemed too good to throw out. All items are in the one picture below: Heated seat bracket with switches fully working exactly as pictured, included the metal support as well. £12 posted. Rota high top black centre caps x2, Both are brand new I think didn't use them only fit, I broke the clips on one of them trying to fit when I had a spacer on, so you'll need to glue/silicone/whatever that one on, but the other is perfect. £12 posted 1x camber / toe standard adjustment bolt, the other snapped when removing but this one is good. £7 posted Steering wheel standard DE silver bezel / surround for the cruise control. I removed the cruise switches so don't have them but this surround is solid, has usual marks would need a clean up or refurb. £7 posted Lastly, I had some aluminium (5mm thick) laser cut into square washers for use on the rear subframe same as spl etc 'lockout washers'. They aren't the prettiest cuts but work fine have them fitted on my own. You'll need bolts but they're actually available on eBay for cheap that are perfect size. £7 posted for 4 (full set) Quote Link to comment Share on other sites More sharing options...
slipstream Posted November 10, 2016 Share Posted November 10, 2016 Hi mate do you still have the camber / toe standard adjustment bolt ? Thanks, Stuart. Quote Link to comment Share on other sites More sharing options...
cascade88 Posted November 10, 2016 Author Share Posted November 10, 2016 Everything still available although may end up keeping the rota caps. Quote Link to comment Share on other sites More sharing options...
slipstream Posted November 10, 2016 Share Posted November 10, 2016 PM sent Quote Link to comment Share on other sites More sharing options...
