CarlW Posted October 29, 2016 Share Posted October 29, 2016 (edited) Well I've had my 350Z a week now and I have to say it's been a week of discoveries, primarily because I was apparently so pumped about buying it I didn't pay attention to what I was buying. When I bought the car the only upgrade I noticed was a Pop Charger (fairly obvious hence I saw it), since then though I've made some further discoveries: Kinetix Plenum HFCs (only noticed those because the CEL light came on so I took a look expecting to have to replace the CATs) Upgraded Exhaust (also noticed when checking the CATs) I've got no idea what make the HFCs or Exhaust is but considering I was budgeting around £1500 for those items I'm not going to look a gift horse in the mouth! Anyway I bought a few items to fit to the car, new stereo, stubby aerial, vent trims, boot struts etc but I was thinking since the last owner spent a fair amount of performance upgrades to would be a shame to waste them. Hence my post, sorry it's taken so long, but does anyone know any good places for a remap in the South West or should I plan a trip across the country to get an UpRev? Any advice greatly appreciated Edited October 29, 2016 by CarlW Quote Link to comment Share on other sites More sharing options...
Bandit Posted October 29, 2016 Share Posted October 29, 2016 Sounds a good buy, enjoy it 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted October 29, 2016 Share Posted October 29, 2016 From your location it's a bit of a drive but I'd use Horsham Developments and get an UpRev done if it was me. Link: http://h-dev.co.uk/our-services/mapping-and-dyno-hire/?v=79cba1185463 Used them myself and it was worth the drive from where I live. 1 Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted October 29, 2016 Share Posted October 29, 2016 If you didnt know about those bits how do you know its not mapped already? 1 Quote Link to comment Share on other sites More sharing options...
longsh07 Posted October 29, 2016 Share Posted October 29, 2016 (edited) I agree with Jetpilot, best check if it has been UpRev remapped already. If you have cruise control, hold the top switch down to 'coast/set' and press the cancel button anything between 1 to 5 times then release 'coast/set'. The cruise light should flash corresponding to the number of times you pressed cancel. This is how you switch between maps. I have no idea if its standard across the board or this is just what Abbey set on their remaps but maps 1, 2 and 3 are different throttle response levels, 4 is a valet map which is speed/rev limited, and map 5 is for running 95 octane just in case you cant find premium stuff. 5 is also rev limited lower than stock. If you don't have cruise control I dont know of an easy way to check I'm afraid. Edited October 29, 2016 by longsh07 1 Quote Link to comment Share on other sites More sharing options...
CarlW Posted October 29, 2016 Author Share Posted October 29, 2016 Thanks all, I'll try the suggestion to see if it's already been uprev remapped Quote Link to comment Share on other sites More sharing options...
GMballistic Posted October 29, 2016 Share Posted October 29, 2016 Fyi longsh7 AFAIK my Zed never had switchable maps after it's UpRevs were done (once before FI & once again when I was FI) and yes I had cruise control so that feature maybe at the mappers discretion to add or only if the customer specifies they want it. @CarlW ~ I assumed as you mentioned your EML has come on in-conjunction with you mentioning the HFC's that you had done a code check which showed the secondary O2 sensors at fault which is common on cars with HFC's or De-Cats if they haven't had the secondary O2 sensors switched off after an UpRev. If you don't know why the EML has come on then you're really best off getting the code read before doing anything else. 1 Quote Link to comment Share on other sites More sharing options...
