Oem TCAs
Terence Bower
TCA = Tracking Control Arm, usually lower A-arms.
May I ask if you bought those cheap chinese sets that look almost identical to oem on ebay? And if so, what problem you had? I haven't bought any, but I was thinking I would when I was a bit more flush.
Edited by Aashenfox
Unfortunately yes I did.Problem being they are mow nearly as noisy as the originals were.Not bad when the original items had done 113000 milesvwereas the cheap chinese versions gave about 4000 mles.Not impressed with the atitude of the suppliers either-hence the complaintvto Pay Pal.Note"these are otherwise known as Banana arms
Edited by Terence Bower
Thanks JF - could you post an email link please so I can also have a look? Thanks
FYI Jon, these are the ones that are 'too good to be true', that I was looking at... I'm sure they're coming from the same place as the OP's so there ya have it, the answer is they aren't true! Such a shame, that price is brutal. 150 quid for the set? :blink::stretcher:
http://www.ebay.co.uk/itm/131705128584
Edited by Aashenfox
