Diff Oil??
Terence Bower
Hi,hs anyone bothered changing the diff oil.I was"having play" on our local driving center grounds but having failed to drift the car,I then tried the usual lsd test and was surprised that the diff is not working.
This I suspect is the result of the car having a pretty gentle life before I bought it,in the hands of a woman driver.
Anyone ever freed up a diff just by changing the oil please.
Not too sure about 'freeing' the diff but i changed my diff oil few 100 miles ago . I used genuine nissan i think it takes about 2.7lt if i am not mistaken .
Quite easy job , you just need something to pump the oil into the diff as the filling plug is at the side of the diff if that makes sense
I ordered from Clark Motorsport next day delivery
I thought you were supposed to change the DIf oil every 3 years?
http://www.350z-uk.c...40#entry1158579
This is what we recommend:
Spark Plugs should be changed at 5 years or 54,000 miles
Antifreeze should be changed at 3 years or 36,000 miles
Transmission fluid should be changed at 3 years or 36,000 miles
VLSD fluid should be changed at 3 years or 36,000 miles
Front engine belts should be changed at 3 years or 36,000 miles
Service parts always in stock for the DE and HR :)
Edited by Randy_Baton
  • 3 weeks later...
