martybhoy Posted October 24, 2016 Share Posted October 24, 2016 Hey just wondering if someone with a bit more knowledge than me can help with my current issue. As you will see from picture below my plenum has started to discolour, at first I thought this was dampness due to rain or even just dirt. After reading into it some threads I see that this appears to be one of the signs of oil getting into the plenum? Is that right? I've only noticed this changed in the plenum over the last month or so. Quote Link to comment Share on other sites More sharing options...
coldel Posted October 24, 2016 Share Posted October 24, 2016 Im no expert on this, but I know taking it off is pretty easy (just make sure you have the correct bolt order and torque settings when putting it back) and you could check the inside of the chamber for any evidence? 1 Quote Link to comment Share on other sites More sharing options...
martybhoy Posted October 24, 2016 Author Share Posted October 24, 2016 Thanks coldel. Im trying to avoid doing this myself, although I'll probably take it to the garage as I happen to have the luck where I always get seized bolts, burst hoses or anything that will make it a problem to put back on without some sort of vacuum leak. Just looking to see if anyone has had any similar experience. The car runs as normal, no drop in power and all bolt holes are clear of any oil residue. Quote Link to comment Share on other sites More sharing options...
zebedy Posted October 24, 2016 Share Posted October 24, 2016 just unbolt it, clean inside the plenium and put it back. Install a catch can to trap the oil. Its a simple job. Unless the inside is absoluetly dripping wet I would'nt worry much. 1 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 24, 2016 Share Posted October 24, 2016 Hey just wondering if someone with a bit more knowledge than me can help with my current issue. As you will see from picture below my plenum has started to discolour, at first I thought this was dampness due to rain or even just dirt. After reading into it some threads I see that this appears to be one of the signs of oil getting into the plenum? Is that right? I've only noticed this changed in the plenum over the last month or so. Its just alloy oxidization due to water and air fella, don't know who has told you that its a sign of oil in the plenum but its incorrect, there will always be oil in the plenum itself due to the way the PCV system works. 1 Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted October 24, 2016 Share Posted October 24, 2016 Its just alloy oxidization due to water and air fella, don't know who has told you that its a sign of oil in the plenum but its incorrect, there will always be oil in the plenum itself due to the way the PCV system works. Quite. If oil could seep through metal we would all be screwed 1 Quote Link to comment Share on other sites More sharing options...
martybhoy Posted October 24, 2016 Author Share Posted October 24, 2016 Thanks for your input fellas. I did hope that this discolouration was down to age/the elements. I'll keep an eye on the area incase anything else shows up. Quote Link to comment Share on other sites More sharing options...
