KuroKiddo Posted October 21, 2016 Share Posted October 21, 2016 (edited) Hi guys I was stuck in traffic last night (outside Old Trafford after they finished the match😱) and the temperature gauge went up to just below the red zone, anyway as the traffic ease and got going the temperature dropped quite rapidly and when I had the chance to pull over the fans were spinning, later when I was queuing up at a drive through the temperature garage went up to almost red again and it dropped again when the car got moving, any idea to what's the problem is? Thanks Edited October 21, 2016 by KuroKiddo Quote Link to comment Share on other sites More sharing options...
KuroKiddo Posted October 21, 2016 Author Share Posted October 21, 2016 I touched the top radiator hose and it was warm by the way didn't get a chance to touch the bottom hose Quote Link to comment Share on other sites More sharing options...
KuroKiddo Posted October 21, 2016 Author Share Posted October 21, 2016 Also the fan wasn't blowing hot air while the temperature was high only did so when the temperature gauge dropped to a more normal level Quote Link to comment Share on other sites More sharing options...
davey_83 Posted October 21, 2016 Share Posted October 21, 2016 Low coolant level or air lock in the system if the fans are working? Do the radiator fans work when you turn on the A/C? Quote Link to comment Share on other sites More sharing options...
Snjur Posted October 21, 2016 Share Posted October 21, 2016 Oem radiator or aftermarket? Sent from my SM-G850F using Tapatalk Quote Link to comment Share on other sites More sharing options...
KuroKiddo Posted October 21, 2016 Author Share Posted October 21, 2016 Oem radiator, yeah both fans work I think it could be the thermostat? Because the lower radiator hose was cold and the upper one was warm Quote Link to comment Share on other sites More sharing options...
