Tomh94 Posted October 20, 2016 Share Posted October 20, 2016 Anyone get this loud droning whiney noise at 90mph? Was coming home from trax the other week and manage to get a recording of the noise. It's very loud, but can't pinpoint what it may be. https://vimeo.com/188113019 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted October 20, 2016 Share Posted October 20, 2016 Without looking at the vid, may I ask if the GF/wife is in the car? 5 Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted October 20, 2016 Share Posted October 20, 2016 (edited) Bearing? Mine (04 350) needs both rear wheel bearings at the moment and up above 60mph they get pretty droney (sounds like someone using a power tool in a closed room, or like amplified road noise with a rumbling component). I'd look at the vid to compare, but vimeo is blocked from the corporate network. I'll try on my phone in a minute and let you know if I have any other bright ideas. Edited October 20, 2016 by Aashenfox Quote Link to comment Share on other sites More sharing options...
Tomh94 Posted October 20, 2016 Author Share Posted October 20, 2016 Cheers dude :') I did think wheel bearings but they're usually a low rumbly noise, this is more of a high pitch resonating noise. And unfortunately no, just my friend was in the car :') else that might have explained it Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Irn Bru Posted October 20, 2016 Share Posted October 20, 2016 (edited) Sound's more like a gear box bearing than a wheel bearing. Wheel bearings are easy to check, just jack the car up and try and wiggle the wheelside from side to side, if it moves then there's your problem Edited October 20, 2016 by Irn Bru Quote Link to comment Share on other sites More sharing options...
Tomh94 Posted October 20, 2016 Author Share Posted October 20, 2016 Sound's more like a gear box bearing than a wheel bearing. Wheel bearings are easy to check, just jack the car up and try and wiggle the wheelside from side to side, if it moves then there's your problem That was my thinking also, I get a quieter whine at lower speeds when driving round as well so going to assume it's related. Assuming something like a gearbox bearing isn't going to be cheap. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Irn Bru Posted October 20, 2016 Share Posted October 20, 2016 Sound's more like a gear box bearing than a wheel bearing. Wheel bearings are easy to check, just jack the car up and try and wiggle the wheelside from side to side, if it moves then there's your problem That was my thinking also, I get a quieter whine at lower speeds when driving round as well so going to assume it's related. Assuming something like a gearbox bearing isn't going to be cheap. Sent from my iPhone using Tapatalk Nowt cheap about gearbox work mate Quote Link to comment Share on other sites More sharing options...
Tomh94 Posted October 20, 2016 Author Share Posted October 20, 2016 Yeahh I know, just had the clutch and flywheel replaced. This car's turning into a bit of a money pit Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Roscoe Posted October 20, 2016 Share Posted October 20, 2016 Sounds gearbox related to me Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
glrnet Posted October 20, 2016 Share Posted October 20, 2016 Gearbox, rear axle? Put it in neautral at speed when you have the noise, does it disappear? Quote Link to comment Share on other sites More sharing options...
Alpinaman Posted October 20, 2016 Share Posted October 20, 2016 (edited) Every tingle,whine drone,whistle is heard in these cars... Next to no sound barriers anywhere. The transmission is noisy as standard.... If its the gearbox bearings then it should do it at the same RPM in every gear... Edited October 20, 2016 by Alpinaman Quote Link to comment Share on other sites More sharing options...
Tomh94 Posted October 20, 2016 Author Share Posted October 20, 2016 Right cheers guys, such a number of things I guess. It only does it under load, not sure if you could hear it but in the video it was stopping and starting as I took my foot on and off the accelerator. Starting to get a fainter version of the noise at lower speeds now. Not sure if it's new noises starting or my paranoia unearthing things that were already there. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dicky Posted November 25, 2016 Share Posted November 25, 2016 Yes you can here it going on and off with the accelerator and finding it will be a pain. If you could get hold of a "Mechanics Engine Diagnostic Stethoscope" you could have a mate hold it in the gear lever area, then somewhere on the bulkhead and behind the seats to help locate it. A rolling road would be useful to check around the engine bay area. I had thought to get the back of the car up onto axel stands, put the car in gear to drive the wheels then go around listening, but on reflection that would be a bit dangerous, best to pay for a rolling road diagnostic. Good luck Quote Link to comment Share on other sites More sharing options...
Richf Posted November 25, 2016 Share Posted November 25, 2016 Definitely doesn't do it at all when stationary ? Have we ruled out engine ? Quote Link to comment Share on other sites More sharing options...
Tomh94 Posted November 27, 2016 Author Share Posted November 27, 2016 Definitely doesn't do it at all when stationary ? Have we ruled out engine ? Doesn't do it at all when stationary, only makes the noise at 90, and now 45 and 30. Very strange, only does it under load, when I let off it stops. Sly from kaizer motors said it could be a misaligned clutch plate. So taking a long trip down to kent for his knowledge early next year. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Miller350z Posted December 22, 2016 Share Posted December 22, 2016 Did you ever find out what this was? I have the same problem Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Payco Posted December 22, 2016 Share Posted December 22, 2016 First check you don't have the wife in the passenger seat. Quote Link to comment Share on other sites More sharing options...
Tomh94 Posted December 22, 2016 Author Share Posted December 22, 2016 Not yet unfortunately dude. They do have a noisey transmission as standard. However next year i'm going down to kaizer motors to get a diagnosis from sly. So will update this post then. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Miller350z Posted December 22, 2016 Share Posted December 22, 2016 OK I'll keep my eye on it thanks Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
