JoeSwin Posted October 16, 2016 Share Posted October 16, 2016 Hi, Just gone for a drive and my clutch pedal sounds like the door of a haunted house. Ideal for Halloween but not for changing gears. Has anyone else has this before, and where is it likely coming from? Just needinh a bit of lube somewhere? Thanks Quote Link to comment Share on other sites More sharing options...
Mikevv Posted October 16, 2016 Share Posted October 16, 2016 Coming along for an answer, mine has started doing it slightly, figured as long as the gear changes are good and smooth I shouldnt worry too much Quote Link to comment Share on other sites More sharing options...
JoeSwin Posted October 16, 2016 Author Share Posted October 16, 2016 Sounds is more pedal mechanism rather than clutch. I think it's just a dry joint, just hoping someone else has previously solved and knows where best to start Quote Link to comment Share on other sites More sharing options...
evest Posted October 16, 2016 Share Posted October 16, 2016 Not had it mate but best place to start has gotta be lubing the pedal hinges Quote Link to comment Share on other sites More sharing options...
JoeSwin Posted October 16, 2016 Author Share Posted October 16, 2016 Will do tomorrow. Seems like it's the other side of the firewall though Quote Link to comment Share on other sites More sharing options...
wilo Posted October 16, 2016 Share Posted October 16, 2016 Hi, Just gone for a drive and my clutch pedal sounds like the door of a haunted house. Ideal for Halloween but not for changing gears. Has anyone else has this before, and where is it likely coming from? Just needinh a bit of lube somewhere? Thanks pmsl this made me laugh ( door of a haunted house) .following as mine has developed this too. definitely pedal related and also croaks abit if i feather the pedal in a certain way . Quote Link to comment Share on other sites More sharing options...
evilscorp Posted October 16, 2016 Share Posted October 16, 2016 On early de engine it will be the slave cylinder on the outside of the gearbox, pull the rubber back and stick in some grease. 1 Quote Link to comment Share on other sites More sharing options...
evilscorp Posted October 16, 2016 Share Posted October 16, 2016 The newer gearboxes however have the slave in built so unlikely they will squeak. 10x worse if you have bonnet vents as water runs down the top of the engine / gearbox and onto the slave cylinder. =/ Quote Link to comment Share on other sites More sharing options...
JoeSwin Posted October 17, 2016 Author Share Posted October 17, 2016 I'm going to investigate tonight and see if I can stop it with some WD40 to find the issue and then go back in wth proper grease Quote Link to comment Share on other sites More sharing options...
Spoons Posted October 18, 2016 Share Posted October 18, 2016 I'm going to investigate tonight and see if I can stop it with some WD40 to find the issue and then go back in wth proper grease Hi pal, I wouldn't use WD40 on the clutch pedal joints if I was you. Try a lithium spray grease if you suspect a dry joint. WD40 dissolves grease and will quickly dry up with the heater venting in the footwell and with the amount of use the pedal gets. Just to Confirm is it definitely a squeak with no notchiness. I only ask as I had to make a clutch pedal box repair on mine and it's a bitch of a job but 10 thousand miles on still sweet. I keep meaning to put the fix up on here. it was a full pedal assembly removal job.The pedal has an assistance spring and mini shock, these have a few pins and pivot points to check for dry points. Then there is the main pedal pivot bolt high up under the steering column and the master cylider pushrod. Hope your flexible it's an upside down in the footwell job I'm afraid. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Adam B Posted October 19, 2016 Share Posted October 19, 2016 Had same problem on mine, gets worse the more you drive it. As stated above It was the slave cylinder, return spring had snapped inside. New cylinder, fresh fluid and a bleed, job done. Its not a squeaking gate hinge, I would not recommend wd40 either. 1 Quote Link to comment Share on other sites More sharing options...
JoeSwin Posted October 19, 2016 Author Share Posted October 19, 2016 Thanks. I used spray grease in the end. Was in the engine bay side of the firewall so didn't expect it to be pedal assembly. Seems to have done the job for now Quote Link to comment Share on other sites More sharing options...
JoeSwin Posted October 19, 2016 Author Share Posted October 19, 2016 Was definitely a dry joint Quote Link to comment Share on other sites More sharing options...
Devilishdeb Posted October 19, 2016 Share Posted October 19, 2016 Mine was squeaky until reservoir was filled up gave spring extra pressure. Squeak first got worse then started sticking up major hills. Hope it helps Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Devilishdeb Posted October 19, 2016 Share Posted October 19, 2016 Had same problem on mine, gets worse the more you drive it.As stated above It was the slave cylinder, return spring had snapped inside. New cylinder, fresh fluid and a bleed, job done. Its not a squeaking gate hinge, I would not recommend wd40 either. Completely agree. Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
