wilo Posted October 15, 2016 Share Posted October 15, 2016 hey guys i posted a thread about my oil pressure when i first bought the car in june as was idling about 15-20 psi. any how consenses was it was in range for a high milage 2004 DE . Anyhow ....iv just had a plenum spacer miltek resonator bypassed and a GT spec throttle controller fitted . due to yorks sh1tty weather iv only just been able to take her out for a decent run since the mods fitted last week . every thing was okay for 90% of the journey and oil pressure was reading 20psi at idle untill about 5 mile from home on the return journey when it started to read about 10psi every time i stopped at a junction etc . any ideas guys ? could any of the mods be related to oil pressure? ....pics to follow Quote Link to comment Share on other sites More sharing options...
wilo Posted October 15, 2016 Author Share Posted October 15, 2016 Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 15, 2016 Share Posted October 15, 2016 did you check or change oil when you first got it? have you done either since you got it? Quote Link to comment Share on other sites More sharing options...
wilo Posted October 15, 2016 Author Share Posted October 15, 2016 did you check or change oil when you first got it? have you done either since you got it? yes i check it religiously mate.also its just had a full service done . i checked oil yesterday morning from cold and it was just slightly under max Quote Link to comment Share on other sites More sharing options...
jumping350 Posted October 15, 2016 Share Posted October 15, 2016 Maybe faulty gauge, cant see any of the mods having an effect unless something was missed during plenum install but would of thought you would have idle issues with that one, im sure Alex or someone will chime in with some thoughts shortly 1 Quote Link to comment Share on other sites More sharing options...
wilo Posted October 15, 2016 Author Share Posted October 15, 2016 yea idle is fine tbh ..only other thing iv noticed is it seems a bit jumpy on throttle responce / setting off but that could be down to having SP10 on throttle controller most of the time ? Quote Link to comment Share on other sites More sharing options...
MikeyM Posted October 15, 2016 Share Posted October 15, 2016 SP10 on the throttle setting will Deffo make it sensitive to say the least lol If I'm not running it on Norm, I'm on SP07 for me and I have all the mods etc as well..apart from remap Quote Link to comment Share on other sites More sharing options...
Richf Posted October 15, 2016 Share Posted October 15, 2016 if you are worried put a independent gauge on it but thats looks pretty normal to me and i wouldnt worry about it 1 Quote Link to comment Share on other sites More sharing options...
wilo Posted October 15, 2016 Author Share Posted October 15, 2016 SP10 on the throttle setting will Deffo make it sensitive to say the least lol If I'm not running it on Norm, I'm on SP07 for me and I have all the mods etc as well..apart from remap i cant go back to normal now lol.love SP10 the difference is night and day and my preferred driving setting . i too am also awaiting a remap to complete the mods but dare not spend any more money with Xmas coming up so that will be done in the new year depending on the outcome of the oil pressure issue 1 Quote Link to comment Share on other sites More sharing options...
wilo Posted October 15, 2016 Author Share Posted October 15, 2016 if you are worried put a independent gauge on it but thats looks pretty normal to me and i wouldnt worry about it where would i get a gauge from that fits .and does yours idle as low as mine Quote Link to comment Share on other sites More sharing options...
Richf Posted October 15, 2016 Share Posted October 15, 2016 if you are worried put a independent gauge on it but thats looks pretty normal to me and i wouldnt worry about it where would i get a gauge from that fits .and does yours idle as low as mine I've never owned a DE but seen one or two . You can get them on ebay http://www.ebay.co.uk/itm/MECHANICS-MECHANICAL-REMOTE-MASTER-ENGINE-OIL-PRESSURE-GAUGE-TESTING-KIT-WR-/122122671367?hash=item1c6f141507:m:mOf-43SW0dGtHIgdq7Dzk0A 1 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 15, 2016 Share Posted October 15, 2016 You said it has just had a service, has the oil grade been changed? could just be a failing oil pressure sensor/gauge. Quote Link to comment Share on other sites More sharing options...
wilo Posted October 15, 2016 Author Share Posted October 15, 2016 if you are worried put a independent gauge on it but thats looks pretty normal to me and i wouldnt worry about it where would i get a gauge from that fits .and does yours idle as low as mine I've never owned a DE but seen one or two . You can get them on ebay http://www.ebay.co.uk/itm/MECHANICS-MECHANICAL-REMOTE-MASTER-ENGINE-OIL-PRESSURE-GAUGE-TESTING-KIT-WR-/122122671367?hash=item1c6f141507:m:mOf-43SW0dGtHIgdq7Dzk0A cheers Rich and by the description it quotes most cars require 10psi for 1000RPM so maybe its not so bad unless 350s require more pressure 1 Quote Link to comment Share on other sites More sharing options...
Richf Posted October 15, 2016 Share Posted October 15, 2016 Should be 1 bar/ 14 psi at idle but the onboard gauges and sensors cant be relied upon 100% 1 Quote Link to comment Share on other sites More sharing options...
Ekona Posted October 15, 2016 Share Posted October 15, 2016 Meh, as long as it's between the min and the max it's fine. I wish Nissan would just remove that gauge, it causes more sleepless nights than it prevents! 2 Quote Link to comment Share on other sites More sharing options...
davey_83 Posted October 15, 2016 Share Posted October 15, 2016 On a separate note my alternator read similar just before it packed in, replaced and it shows a healthy 14.2v Quote Link to comment Share on other sites More sharing options...
wilo Posted October 15, 2016 Author Share Posted October 15, 2016 On a separate note my alternator read similar just before it packed in, replaced and it shows a healthy 14.2v mmmm i was waiting for someone to notice that too. it does seem lower than normal but i was more preoccupied with oil pressure and forgot about it . is it certainly the alternator or can a failing battery give similar readings on the gauge Quote Link to comment Share on other sites More sharing options...
davey_83 Posted October 15, 2016 Share Posted October 15, 2016 Battery is shown on ignition on, alternator chare rate is shown when engine running. Fingers crossed all is ok mind 1 Quote Link to comment Share on other sites More sharing options...
wilo Posted October 16, 2016 Author Share Posted October 16, 2016 Battery is shown on ignition on, alternator chare rate is shown when engine running. Fingers crossed all is ok mind so am i thinking correct ... if i go to the car this morning and it is an alternator problem .... when i turn (just) the ignition on it will display under 12 volts showing battery hasnt been charging properly? Quote Link to comment Share on other sites More sharing options...
JoeSwin Posted October 16, 2016 Share Posted October 16, 2016 I'd imagine ignition on engine off should show approx 12v anyway, given its a 12v battery (often only slightly above. ) Engine running should be higher Quote Link to comment Share on other sites More sharing options...
davey_83 Posted October 16, 2016 Share Posted October 16, 2016 Just a smidge under 12v for cranking is fine, an issue can occur alternator wise if it under charges as well as overcharges. Quote Link to comment Share on other sites More sharing options...
Olly350z Posted October 18, 2016 Share Posted October 18, 2016 Noticed on mine last night that the voltage was the same as yours, with radio, lights, heating and seats on etc. Obviously load on the alternator will create varience. Is mine dying too? Quote Link to comment Share on other sites More sharing options...
wilo Posted October 18, 2016 Author Share Posted October 18, 2016 Noticed on mine last night that the voltage was the same as yours, with radio, lights, heating and seats on etc. Obviously load on the alternator will create varience. Is mine dying too? mmmm mine wasnt under load at the time and not had chance to recheck it yet as she is in bits on the drive while centre console etc is getting sprayed .hopefully will have her back on the road tomorrow and test again Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 18, 2016 Share Posted October 18, 2016 The voltage you see at the gauge will vary a lot depending on system load, and battery charge state, you should see anything from 12.8v to 14.2v. however charging voltage is not really an indication of the alternators health, just the system load. 1 Quote Link to comment Share on other sites More sharing options...
