davey_83 Posted October 15, 2016 Share Posted October 15, 2016 (edited) What's the idea behind the removeable foam block at the bottom of the OE air box? David Edited October 17, 2016 by davey_83 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted October 15, 2016 Share Posted October 15, 2016 Was that inside it? Pretty sure (99.9%) that my original airbox never had that inside of it although it has been a long time since I remember looking inside it. Maybe some current owners can check theirs for you. Failing that zmanalex would probably know. Quote Link to comment Share on other sites More sharing options...
GappySmeg Posted October 15, 2016 Share Posted October 15, 2016 I recently removed my airbox to fit flyboys velocity stack... deffo did not have a lump of black sponge/foam in it. Quote Link to comment Share on other sites More sharing options...
Mopedmark Posted October 15, 2016 Share Posted October 15, 2016 Got 3 in the shed from what I have taken off Zeds and non have had that Quote Link to comment Share on other sites More sharing options...
Zeezeebaba Posted October 15, 2016 Share Posted October 15, 2016 I have two, one on the car and one in the garage. Just checked and neither have any foam in them. Quote Link to comment Share on other sites More sharing options...
ZEUS Posted October 15, 2016 Share Posted October 15, 2016 Mines not got it either, some power mod the rest of us don't know about! Quote Link to comment Share on other sites More sharing options...
GMballistic Posted October 15, 2016 Share Posted October 15, 2016 Mines not got it either, some power mod the rest of us don't know about! Yep just Googled it and all the Americans are doing it, ...good for 20Bhp apparently. ;) 1 Quote Link to comment Share on other sites More sharing options...
davey_83 Posted October 15, 2016 Author Share Posted October 15, 2016 I have both types of DE air box and both have the foam inside, how odd. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted October 15, 2016 Share Posted October 15, 2016 I have both types of DE air box and both have the foam inside, how odd. That's very odd. I can't see it doing anything worth while so I'd just bin it if it was me but then why was it there in the first place?! Absorbing noise maybe? Edit: Just did a search to see what I could unearth... Link to some more threads on it: http://www.350z-uk.com/topic/63177-airbox-foam-insert/ http://my350z.com/forum/intake-exhaust/181372-foam-packing-inside-stock-airbox.html https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=350z%20airbox%20with%20foam%20in%20it Quote Link to comment Share on other sites More sharing options...
Exec Posted October 15, 2016 Share Posted October 15, 2016 Mine had it, mine had small pieces coming away with age so I removed it to prevent them getting sucked in. I didn't know until now it came with the airbox. Exact same. I still have it in the garage. Quote Link to comment Share on other sites More sharing options...
gsexr Posted October 15, 2016 Share Posted October 15, 2016 Have you got square pants to go with it 2 Quote Link to comment Share on other sites More sharing options...
davey_83 Posted October 15, 2016 Author Share Posted October 15, 2016 (edited) Absolute legend, cheers man. Il leave it there as Nissan motor company is more clever-ra than me haha. at a glance, helps direct incoming air straight to the filter at least. Edited October 15, 2016 by davey_83 Quote Link to comment Share on other sites More sharing options...
-blade- Posted October 16, 2016 Share Posted October 16, 2016 The standard box i have but don't use also has this foam. I assumed it was either a water drainer trap? though can't see it being very effective. The question is do you gain 30hp by fitting the foam? or by removing it ? 1 Quote Link to comment Share on other sites More sharing options...
Paul K Posted October 16, 2016 Share Posted October 16, 2016 Not in mine Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 17, 2016 Share Posted October 17, 2016 Mine neither. Quote Link to comment Share on other sites More sharing options...
350_Jer Posted October 17, 2016 Share Posted October 17, 2016 I noticed I had the foam in my airbox when I changed my air filter. I just took a guess that it could be to maybe quieten down the induction noise a bit? Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted October 17, 2016 Share Posted October 17, 2016 (edited) I'd second the catching water drops before the filter, probably useless. On the subject, is it worth spending the money on a K&N panel ? Edited October 17, 2016 by Willsy1980 Quote Link to comment Share on other sites More sharing options...
glrnet Posted October 18, 2016 Share Posted October 18, 2016 Just a thought, are there any holes drilled in the bottom of the air box? I seem to remember a few years back there was talk of drilling holes in the bottom of the standard air box to increase induction noise!! If that's the case maybe someone shoved the foam in to quieten things down? Like Mopedmark, there's none in mine and none in the 2 I have in the garage. Quote Link to comment Share on other sites More sharing options...
GappySmeg Posted October 18, 2016 Share Posted October 18, 2016 I've just had a closer look... mine DOES have the foam insert in! To clarify whereabouts it is, with airbox in-situ and the air filter removed, peer down to the bottom... the foam is NOT on the bottom, but squeezed into a recess at the bottom of the airbox (the recess extends into the rearwards wall of the airbox). Quite hard to spot, actually. Cannot conceive of what it's use might be 1 Quote Link to comment Share on other sites More sharing options...
