TIMING CHAIN due ?
wilo
hey guys ..
finally got hold of previous owner of my 350z DE
asked when timing chain was done and he thinks at 90000 .
i bought her in june at 129000 and just had a full service done last week at 132000 miles.
so can someone please tell me ....when does the chain require doing again?
Unless it's making a noise they should last the life of the engine from what I hear, ...the chain that is. The tensioners though may need changing due to wear but again it's not something you hear done very often although it might happen more often now with the cars getting older/higher mileage.
The chains though can stretch and if that did happen your timing would be out so it should be throwing up the EML/error codes or at the very least be rattling I'd have thought as if the chain has stretched the chain would most likely be hitting the casing in that case (which causes the rattle from what I gather).
I guess with the mileage getting as high as yours is it could be an issue but as you say the timing chain and tensioners have already been done at 90K miles by the previous owner then I really wouldn't worry about it (imo). ;)
Some more "related" threads:
http://www.350z-uk.com/topic/59171-possible-timing-chain-needs-changing/
http://www.350z-uk.com/topic/71799-timing-chain-noisechange/
http://www.350z-uk.com/topic/65092-cam-chain-change/
http://www.350z-uk.com/topic/68978-cam-chain-tensioner/
thanks GM .
no apart from the usual thrust bearing rattle the engine sounds very healthy for its age .
i am waiting on confirmation today as to if it was definitely done but panic over i think regarding your info .
cheers :)
