Jk-boi Posted October 9, 2016 Share Posted October 9, 2016 So the guide tarmac sent looks extremely easy to follow Question is does the car already have the holes and bolts for side steps/skirts if the car didn't come with a skirt as standard? Most fitting guides I've researched people already have the holes due to taking off original skirts, they just needed to drill the side steps to match. I'm away from the car at the minute so can't physically look but the day I get back I'm going to try and fit them. I see on other cars people self tap or glue them on but bolting is always better for a secure fit. Cheers in advance! Quote Link to comment Share on other sites More sharing options...
valy Posted October 9, 2016 Share Posted October 9, 2016 (edited) the Zed has got the holes already hence the detailed measurement Tarmac has sent with them for when you drill the holes is basically measure/drill/bolts off/sides on/bolts on took me about 1 hour hope this helps Edited October 9, 2016 by valy Quote Link to comment Share on other sites More sharing options...
coldel Posted October 9, 2016 Share Posted October 9, 2016 Just to confirm, you dont have to remove the skirts, you just take the bolts out and refit with the step in place. Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted October 9, 2016 Share Posted October 9, 2016 As above but you may find a piece of rubber towards the back of the skirts that stops the side step fitting flush. Its not important so just cut the rubber out if its in your way. Quote Link to comment Share on other sites More sharing options...
Jk-boi Posted October 9, 2016 Author Share Posted October 9, 2016 Thanks for the replies guys Look forward to getting them on rather than decorating my living room 😂 Quote Link to comment Share on other sites More sharing options...
veilside z Posted October 10, 2016 Share Posted October 10, 2016 Will make your ride look even closer to the ground once fitted buddy 1 Quote Link to comment Share on other sites More sharing options...
Jk-boi Posted October 22, 2016 Author Share Posted October 22, 2016 Will make your ride look even closer to the ground once fitted buddy Can confirm this is true ! For anyone else these really are easy to fit the hardest part was remebering where my stanley knife was to cut away the little rubber bit. 1 Quote Link to comment Share on other sites More sharing options...
