Andyk75 Posted October 7, 2016 Share Posted October 7, 2016 Hi guys , wonder if anyone can tell me what the fault code is in this video and what needs replacing or repairing as im hoping its something i can do myself thats not going to be too costly. Thanks Andy https://www.youtube.com/watch?v=Xr0wdueRsE8&feature=youtu.be Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted October 8, 2016 Share Posted October 8, 2016 I know, how odd, it looks like 2 then 11 then 10 (=0) then 3. No idea what 11 flashes means . Quote Link to comment Share on other sites More sharing options...
Andyk75 Posted October 8, 2016 Author Share Posted October 8, 2016 anyone? Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 8, 2016 Share Posted October 8, 2016 A couple of things; i thought the CEL flashed slowly 10 times before flashing quickly then giving you the code and once the fast flashes for the code had stopped it flashed slowly 10 times again. Secondly could the 11 flashes then 10 flashes then 3 flashes mean that the code is P1103 which is a problem with the MAP sensor heater?? Just a thought. I suppose the only surefire way to get a definitive answer would be to plug in a code reader. Quote Link to comment Share on other sites More sharing options...
Andyk75 Posted October 8, 2016 Author Share Posted October 8, 2016 its defientely got me confused Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 8, 2016 Share Posted October 8, 2016 Andy, why don't you pop into the Cougarstore tomorrow and ask Mitz nicely if he'll plug in his code reader, that way you'll know for sure whats wrong and the course of action you need to take in order to fix it?? He's in Leicester so can't be that far away from you. It just seems strange that you're only getting 2 slow flashes before it goes into the fast flashing series to give you the code. Quote Link to comment Share on other sites More sharing options...
karlh Posted October 8, 2016 Share Posted October 8, 2016 The light is flashing the code P2A03. The 11 flashes indicates an A. Earlier cars didn't use letters in the DTCs, so that may be why some are confused. P2A03 is an air/fuel sensor 1 (bank 2) fault. Quote Link to comment Share on other sites More sharing options...
Andyk75 Posted October 8, 2016 Author Share Posted October 8, 2016 The light is flashing the code P2A03. The 11 flashes indicates an A. Earlier cars didn't use letters in the DTCs, so that may be why some are confused. P2A03 is an air/fuel sensor 1 (bank 2) fault. ok great, whats the fix for this? could it be dirty air filter or something simple? Quote Link to comment Share on other sites More sharing options...
karlh Posted October 8, 2016 Share Posted October 8, 2016 Not sure about the fix. You need to check the Service Manual. Quote Link to comment Share on other sites More sharing options...
ZEUS Posted October 8, 2016 Share Posted October 8, 2016 As Sam says go and see Mitz at cougar store for a definate code and prognosis. Saves guessing at it. Quote Link to comment Share on other sites More sharing options...
Andyk75 Posted October 8, 2016 Author Share Posted October 8, 2016 yea will have my car booked in there soon for mot and service so will look into it then Quote Link to comment Share on other sites More sharing options...
samsniss350z Posted October 10, 2016 Share Posted October 10, 2016 Oh yeah Karl I've just found it; P2A03 = Air/Fuel sensor 1 bank 2 circuit range/performance. What the hell it means though other than the sensor is knackered, I'm afraid I haven't got a bloody clue. I'd still be inclined to let Mitz do his magic. Quote Link to comment Share on other sites More sharing options...
karlh Posted October 10, 2016 Share Posted October 10, 2016 Oh yeah Karl I've just found it; P2A03 = Air/Fuel sensor 1 bank 2 circuit range/performance. What the hell it means though other than the sensor is knackered, I'm afraid I haven't got a bloody clue. I'd still be inclined to let Mitz do his magic. I totally agree that a full diagnostic is the best way to go. The Service Manual describes the conditions that cause this fault to be recorded as: a. The output voltage computed by ECM from the A/F sensor 1 signal is shifted to the lean side for a specified period, or b. The output voltage computed by ECM from the A/F sensor 1 signal is shifted to the rich side for a specified period. The specified period is not defined. Possible causes listed in the manual are a bad sensor or sensor heater, excessively low or high fuel pressure, a bad injector, or an intake air leak. I suspect the sensor is the faulty part here. Quote Link to comment Share on other sites More sharing options...
