Scott TMN Posted October 4, 2016 Share Posted October 4, 2016 Trying to swap out my VTC solenoids on my 370. Moved the expansion tank out of the way, access to both is fine and done the left one no problems. However the right one, as I pull it out it hits a pipe below, so i cant quite get it out. Looking for advice how to do so? Should I be able to, but just being stupid? Would removing the pipe be a ball ache? Fluids everywhere, air in the system etc? Can I remove the cover that the solenoid actually bolts to? Cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 4, 2016 Share Posted October 4, 2016 The VTC cover could be partially removed to facilitate the removal of the solenoid, however I would just disconnect the hose. Quote Link to comment Share on other sites More sharing options...
Scott TMN Posted October 4, 2016 Author Share Posted October 4, 2016 On 04/10/2016 at 19:15, ZMANALEX said: The VTC cover could be partially removed to facilitate the removal of the solenoid, however I would just disconnect the hose. cheers for the reply Alex, I take it that would leak out some oil? Whats in the hose? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 4, 2016 Share Posted October 4, 2016 You should not experience any oil loss, however the cover will be tight on the dowels. The hose is coolant. Quote Link to comment Share on other sites More sharing options...
Scott TMN Posted October 5, 2016 Author Share Posted October 5, 2016 ok mate cheers. Would I need to worry about air getting in the system after removing the coolant hose? Swaying toward removing the cover because of this? Cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 5, 2016 Share Posted October 5, 2016 Nah, if you are quick you can stuff a couple of rags into each opening once you pull the hose which will stem the loss of coolant. Carry this out when the coolant is cold. 1 Quote Link to comment Share on other sites More sharing options...
Scott TMN Posted October 5, 2016 Author Share Posted October 5, 2016 Ok might give this a try. Thanks a lot. Quote Link to comment Share on other sites More sharing options...
