Deee26 Posted October 3, 2016 Share Posted October 3, 2016 Hello all, I've tried searching but cannot get the search function to work so figured I would start a new thread. Whilst driving recently my pedal started feeling spongy and within in a mile or two had dropped to the floor. I figured it was a hydraulic issue as I've never had any issues with the clutch. Whilst I waited for the tow truck I noticed a few drips of clutch fluid appear on the floor. A few days later when I had chance to get under the car I couldn't for the life of me see any trace of where the fluid had come from however a quick google indicated a common issue on the 370Z's being the clutch slave cylinder (CSC) failing. This would tie in with what I am experiencing, and also the fact that I couldn't see any obvious signs of the fluid coming from anywhere. I suspect a little has found it's way out of the bottom of the bellhousing. I'm not a great fan of taking my car to garages as I generally feel like everything is rushed and often cars don't come back the same, so I'm going to do it myself. Ohh and saving over £500 on labour is another plus! Being rear wheel drive it looks very straight forward. A new CSC from Nissan weighed in at £115 Have many people have this issue? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted October 3, 2016 Share Posted October 3, 2016 Quite a common issue and pointless replacing like for like as there is a flaw in the OEM CSC. Best to replace the CSC with an upgraded unit and perhaps consider replacing the clutch and fly as well (after market) or at least remove and inspect to reach an informed decision. Quote Link to comment Share on other sites More sharing options...
bakseedaa Posted October 5, 2016 Share Posted October 5, 2016 Mine went about 5 weeks ago. As Zman says don't put a oem one back in they are fatally flawed. I uprated my clutch and flywheel at the same time also. 1 Quote Link to comment Share on other sites More sharing options...
Deee26 Posted December 17, 2016 Author Share Posted December 17, 2016 There was far too much life left on my clutch to warrant a replacement. Clearly the slave had just developed a small weeping leak that had just dribbled down the side of the bellhousing. I cannot see a scanrio where the slave could fail in such a catastrophic way that fluid would reach the clutch. I can understand why, when paying a garage a significant amount of money, it would make sense to change the clutch if the car has covered some milage. However being a RWD car the gearbox off is a very straightforward and speedy job, therefore for me 'if it aint broke (or about to brake) then don't fix it.' Quote Link to comment Share on other sites More sharing options...
Kev T Posted December 17, 2016 Share Posted December 17, 2016 The Z1 store in the USA do an uprated CSC kit which is assembled outside the bellhousing ( plainly a more sensible design ) for easy maintenance. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 17, 2016 Share Posted December 17, 2016 On 17/12/2016 at 11:33, Kev T said: The Z1 store in the USA do an uprated CSC kit which is assembled outside the bellhousing ( plainly a more sensible design ) for easy maintenance. This one, about $400: Quote Link to comment Share on other sites More sharing options...
Ebized Posted December 17, 2016 Share Posted December 17, 2016 Seems like that ^^^^ would be $400 well spent when a replacement becomes necessary Quote Link to comment Share on other sites More sharing options...
