colesl4w Posted September 26, 2016 Share Posted September 26, 2016 (edited) Hi all, Well.. wonky bolts, but sure. I know this question has been asked in many shapes and forms over the years, but I struggled to find a definitive answer. Any help would be greatly appreciated. My rear camber & toe bolts, and my front toe bolts, are seized. I'm currently lowered 17mm on Tein s-techs. One mechanic has said I will need just new bolts, another has said I will need new arms too. They didn't do the work there and then as they were worried about snapping the bolts and my car being stuck there with no spares. I have circled in red the parts the mechanic has said are seized and need to be freed up or replaced. Rear camber and toe: Front toe: My questions: - Are these bits even labelled right lol? Going off literally what the guy pointed at. - I see there is a highly recommended Eibach rear camber kit for about £180. Will this kit alone replace all of my camber and toe-related seized parts in the rear, or is there a chance I need extra things? - I see you can get just camber/toe bolts for the rearwhich apparently give greater correction - these cost £55 - would they suit my needs instead of the arm kit? - Where can I get new toe bolts for the front? I haven't managed to find those. Is there a chance I would need more than just bolts for the front toe? - If I got all these things, would this allow me to get a complete alignment without worrying about seizing? I don't mind spending a little extra to just get this all sorted in one go rather than faffing about going to/from a mechanic with different parts. It's such a hassle leaving the car in and getting lifts to/from work just for him to come back and go "ah you need X also". Thank you so much for your help as always guys. Apologies for these questions! I have bought wrong parts in the past and really don't want to repeat that again! Edited September 26, 2016 by colesl4w Quote Link to comment Share on other sites More sharing options...
colesl4w Posted September 27, 2016 Author Share Posted September 27, 2016 Bumpy bump Quote Link to comment Share on other sites More sharing options...
Richf Posted September 27, 2016 Share Posted September 27, 2016 There isnt a toe bolt for the front thats the track rod end and I'd be surprised if that snapped, but you can buy new ones from ECP , the camber bolts do snap and you can get them from Nissan but they arent cheap, the reason i expect they recommended new arms is that you have run out of adjustment , as to whether the eibach kit will solve that I dont know Quote Link to comment Share on other sites More sharing options...
colesl4w Posted September 27, 2016 Author Share Posted September 27, 2016 Thanks Rich Quote Link to comment Share on other sites More sharing options...
evilscorp Posted September 27, 2016 Share Posted September 27, 2016 Eibach kit will do on the rear, there is a SPL? Lock out kit that uses square rather than round cams. Quote Link to comment Share on other sites More sharing options...
KyleR Posted September 30, 2016 Share Posted September 30, 2016 I might have some OEM's in the garage if you want to borrow just incase they snap? 1 Quote Link to comment Share on other sites More sharing options...
colesl4w Posted December 9, 2016 Author Share Posted December 9, 2016 On 30/09/2016 at 12:32, KyleR said: I might have some OEM's in the garage if you want to borrow just incase they snap? Hi Kyle, Argh I have literally only just seen this! Thanks very much for the offer. All sorted now though - got the Eibach bolt kit fitted and we are now all back in line. Thanks again. Quote Link to comment Share on other sites More sharing options...
