bdabinett Posted March 10, 2006 Share Posted March 10, 2006 Someone mentioned posting some of the common warranty issues, so here's my first one. Synchromesh on 6th gear needs replacing. Symptoms? Nearly everytime you select 6th it will 'graunch'. Got mine done under warranty. Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted March 10, 2006 Share Posted March 10, 2006 Good result. This is pretty widely known now at dealerships and generally they will assign a top technician or whatever handle (fancy title) they have to test drive the car. Based on that report and assuming the symptoms are repeatable - warranty kicks in, no problem. It has to be noted that this situation has only arisen because of sites here and in the US promoting these 'problems' Quote Link to comment Share on other sites More sharing options...
steve_b Posted March 10, 2006 Share Posted March 10, 2006 All, I too had this and they replaced some bits in the box....did not tell me exactly what but did the trick. steve Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted March 10, 2006 Share Posted March 10, 2006 It has been reported in the US that using a Synthetic Gear Oil can help in the early stages; however once you start grinding that metal ........... Quote Link to comment Share on other sites More sharing options...
Removed Posted March 11, 2006 Share Posted March 11, 2006 I have had that intermittently, but seems ok now! haven't let it "grind" tbh, as when I felt the gear not going in, I've never really released the clutch, thus avoiding the grinding (apart from once! lol) Will change the gearbox oil to synthetic soon enough, and maybe if it gets worse I'll try the warranty route. Quote Link to comment Share on other sites More sharing options...
