wilo Posted September 19, 2016 Share Posted September 19, 2016 okay im having real difficulties getting these parts sorted and pms to traders are so slow on replying . im needing.... bushing for OSF lower suspension arm NSR wheel bearing and hub 1x wheel bolt 1x wheel nut OSF wheel arch liner ( part closest to bumper) the nut and bolt are for 19" rota alloys if that makes a difference. also the garage said i need the hub as well as the bearing ( what ever that means) Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 19, 2016 Share Posted September 19, 2016 I answered your PM and I told you 2 hours ago that I had all these parts in stock: 2 Quote Link to comment Share on other sites More sharing options...
wilo Posted September 19, 2016 Author Share Posted September 19, 2016 I answered your PM and I told you 2 hours ago that I had all these parts in stock: yes but i need a price and a way of paying you...do you have a web page or do I just order through forum Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 19, 2016 Share Posted September 19, 2016 Prices have been sent by PM. 1 Quote Link to comment Share on other sites More sharing options...
Jon T Posted September 20, 2016 Share Posted September 20, 2016 Have you got everything here covered AL? Quote Link to comment Share on other sites More sharing options...
wilo Posted September 20, 2016 Author Share Posted September 20, 2016 (edited) think so ..just a wee problem with the bolt and nut as mine have to match up..ill get a pic Edited September 20, 2016 by wilo Quote Link to comment Share on other sites More sharing options...
wilo Posted September 20, 2016 Author Share Posted September 20, 2016 Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
wilo Posted September 20, 2016 Author Share Posted September 20, 2016 bottom pic you can see where the numpty mechanic snapped the bolt Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 20, 2016 Share Posted September 20, 2016 think so ..just a wee problem with the bolt and nut as mine have to match up..ill get a pic The bolt will be OEM spec AFAIK so Alex or Emperor Tuning should be able to sort you out there. The nut to suit the Rota alloys will most likely have a slightly different taper than OEM to suit the alloys. If either of the above doesn't have those then I'd try Mitz@Cougar Store as he supplied my wheel nuts for the Rotas I used to have on my Zed. Good luck. Quote Link to comment Share on other sites More sharing options...
wilo Posted September 20, 2016 Author Share Posted September 20, 2016 (edited) think so ..just a wee problem with the bolt and nut as mine have to match up..ill get a pic The bolt will be OEM spec AFAIK so Alex or Emperor Tuning should be able to sort you out there. The nut to suit the Rota alloys will most likely have a slightly different taper than OEM to suit the alloys. If either of the above doesn't have those then I'd try Mitz@Cougar Store as he supplied my wheel nuts for the Rotas I used to have on my Zed. Good luck. cheers GM Alex is having a look in his wheel store today so fingers crossed hes got one . tbh the nuts seem to be a very soft metal that i have atm and go out of shape alot easier than iv seen on my other motors Edited September 20, 2016 by wilo Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 20, 2016 Share Posted September 20, 2016 Cheers GM Alex is having a look in his wheel store today so fingers crossed hes got one . tbh the nuts seem to be a very soft metal that i have atm and go out of shape alot easier than iv seen on my other motors Wheel nuts are cheap enough to buy new and from a safety point of view very important so from what you've just said I'd bin the lot of them then imo. Mitz could do you a full brand new set and I'm sure it wouldn't be much money, ...maybe £25 or so at a guess for a decent set. Give him a PM on here or quickest way would be to ring him. Link: http://cougarstore.co.uk/index.php?main_page=contact_us Quote Link to comment Share on other sites More sharing options...
wilo Posted September 20, 2016 Author Share Posted September 20, 2016 Cheers GM Alex is having a look in his wheel store today so fingers crossed hes got one . tbh the nuts seem to be a very soft metal that i have atm and go out of shape alot easier than iv seen on my other motors Wheel nuts are cheap enough to buy new and from a safety point of view very important so from what you've just said I'd bin the lot of them then imo. Mitz could do you a full brand new set and I'm sure it wouldn't be much money, ...maybe £25 or so at a guess for a decent set. Give him a PM on here or quickest way would be to ring him. Link: http://cougarstore.co.uk/index.php?main_page=contact_us yea i think ill do that mate.so a different set from him will fit my existing hub bolts if iv read your other post correctly Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 20, 2016 Share Posted September 20, 2016 yea i think ill do that mate. so a different set from him will fit my existing hub bolts if iv read your other post correctly Yes AFAIK. Just tell him you have a "2004 Nissan 350Z coupe" and you want to buy a full set of wheel nuts to suit your Rota 19" alloys. Mitz will know what you need. Quote Link to comment Share on other sites More sharing options...
wilo Posted September 20, 2016 Author Share Posted September 20, 2016 yea i think ill do that mate. so a different set from him will fit my existing hub bolts if iv read your other post correctly Yes AFAIK. Just tell him you have a "2004 Nissan 350Z coupe" and you want to buy a full set of wheel nuts to suit your Rota 19" alloys. Mitz will know what you need. thanks matey ill do that.may even have a change of colour if there's anything that would suit Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 20, 2016 Share Posted September 20, 2016 Have you got everything here covered AL? Yes Jon thank you. Parts on there way to OP as we speak. Quote Link to comment Share on other sites More sharing options...
