Dicky Posted September 19, 2016 Share Posted September 19, 2016 Noticed a rattle under my 2004 GT (UK) and traced it to one of the cats (offside). The thin metal shield around the cat has rotted away from the flange at one end and has a couple of small rusted holes in as well. Q1...Anyone know if this can be repaired to keep it going as it's just passed it's mot so the cat itself is good. Q2...Would a good used one be ok or would I need a new one. If so anyone know where's the best place to try? Q3...Is this metal shield simply a heat shield or is it to prevent water getting onto the cat itself? Quote Link to comment Share on other sites More sharing options...
Richf Posted September 19, 2016 Share Posted September 19, 2016 its just a shield , some people remove them or secure then with a couple of jubilee clips 1 Quote Link to comment Share on other sites More sharing options...
Dicky Posted September 19, 2016 Author Share Posted September 19, 2016 On 19/09/2016 at 15:46, Richf said: its just a shield , some people remove them or secure then with a couple of jubilee clips So it's not a water protection guard? I understand these things get pretty hot and had thought the guard was to protect them from sudden cooling Quote Link to comment Share on other sites More sharing options...
Richf Posted September 19, 2016 Share Posted September 19, 2016 its more to stop stuff like grass touching it so just bear than in mind when you park 1 Quote Link to comment Share on other sites More sharing options...
Dicky Posted September 19, 2016 Author Share Posted September 19, 2016 On 19/09/2016 at 16:10, Richf said: its more to stop stuff like grass touching it so just bear than in mind when you park Ah that makes sense, many thanks Richf Quote Link to comment Share on other sites More sharing options...
350zedd Posted September 19, 2016 Share Posted September 19, 2016 I would have thought its to protect any vulnerable stuff close by such as plastic pipes, cables from excess heat. How about some exhaust wrap if the shields have rotted? 1 Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 19, 2016 Share Posted September 19, 2016 Most just remove or secure with a weld or tying wire. However, they are there for a reason and if removed extra heat will hit the clutch slave hose on the N/S and the fuel lines on the O/S however these areas can be protected with some form of heat reflective shield. 1 Quote Link to comment Share on other sites More sharing options...
Loggy747 Posted September 19, 2016 Share Posted September 19, 2016 If ever there was a sign to go DECAT this is it..... Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dicky Posted September 19, 2016 Author Share Posted September 19, 2016 On 19/09/2016 at 19:30, ZMANALEX said: Most just remove or secure with a weld or tying wire. However, they are there for a reason and if removed extra heat will hit the clutch slave hose on the N/S and the fuel lines on the O/S however these areas can be protected with some form of heat reflective shield. Thanks Alex, in fact I tied the cover down with Copper wire to stop the rattle for now. Think I'll remove it and see if I can save or extend its life with a bit of creative metal work. Anyway it doesn't seem to be critical as yet. Quote Link to comment Share on other sites More sharing options...
Wizza2000 Posted September 20, 2016 Share Posted September 20, 2016 On 19/09/2016 at 19:30, ZMANALEX said: Most just remove or secure with a weld or tying wire. However, they are there for a reason and if removed extra heat will hit the clutch slave hose on the N/S and the fuel lines on the O/S however these areas can be protected with some form of heat reflective shield. As above mine were hanging off and certain rpm sounded bad, so removed and put extra foil faced heat insulation around both hoses mentioned by ZMANALEX Insulation I used is the same that come standard on the clutch slave hose, plus have braided hose fitted so that helped with clutch line temps Quote Link to comment Share on other sites More sharing options...
Jp606 Posted September 26, 2016 Share Posted September 26, 2016 Yeah I used stainless cable ties on mine as it started rattling. Quote Link to comment Share on other sites More sharing options...
350Z paradise Posted September 27, 2016 Share Posted September 27, 2016 Heat shield bud...got same problem on my 370,once they are rusted they just get worse. i am removing mine over the weekend as many members have advised. Quote Link to comment Share on other sites More sharing options...
