ideas on possible fix
wilo
okay guys just been to pick the 350 up after its service and brakes been done .
on way home i noticed this noise (sounded like those clacker things on kids bike spokes)
any how when i got her home i found this clip sticking out of calliper and looks like its catching on disk studs ...any ideas as to how to fix as it doesnt seem to want to push in flush like near side side
Edited by wilo
The clip is a warning of low pad and should be on the inside face of the disc.
Take it back, once it's corrected look for a different garage for your work.
could i possibly bend it up so its not catching? or do the pads have to taken out and repositioned
could i possibly bend it up so its not catching? or do the pads have to be taken out and repositioned
Edited by wilo
The low warning metal clip should be fixed firmly to the pad, usually by rivets.
The damage is done so just bend it out the way with a large screw driver.
Never ever seen this before and I've changed thousands of sets of pads.
Drive carefully on way back to garage and read the riot act once there.
The pad with the warning device should also be on the inside pad.
Shocking level of service.
cheers zmanalex ill do this ..and will the pads still work fine ? also noticed some fraying of the braided brake line on the same calliper that wasnt there before so looking like that will need replacing also .quite gutted tbh
