wilo Posted September 16, 2016 Share Posted September 16, 2016 (edited) hi guys im looking for advice on where to get 2 parts . just had service done on my 2004 DE And the mech said it needs a new OSF bottom arm ( one under banana arm) also needs a new NSR rear wheel bearing. Edited September 16, 2016 by wilo Quote Link to comment Share on other sites More sharing options...
ZEUS Posted September 16, 2016 Share Posted September 16, 2016 Used I'd try Zmanalex or new I'd try clark Motorsport 1 Quote Link to comment Share on other sites More sharing options...
wilo Posted September 16, 2016 Author Share Posted September 16, 2016 Used I'd try Zmanalex or new I'd try clark Motorsport thanks iv just sent Zmanalex a pm Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 16, 2016 Share Posted September 16, 2016 Moved the thread here wilo to see if you get more interest. Zeus recommendations is what I would have said but also Emperor Tuning for used items. Quote Link to comment Share on other sites More sharing options...
wilo Posted September 16, 2016 Author Share Posted September 16, 2016 Moved the thread here wilo to see if you get more interest. Zeus recommendations is what I would have said but also Emperor Tuning for used items. thanks GM and yea iv dealt with emperor before so ill give him a shout ...cheers pal 1 Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 16, 2016 Share Posted September 16, 2016 You're welcome wilo and good luck. 1 Quote Link to comment Share on other sites More sharing options...
wilo Posted September 16, 2016 Author Share Posted September 16, 2016 (edited) just messaged the mechanic asking what arm i needed and he replied this ..... "It's front lower arm ball joint on hub end and Bush on inner where it goes in to subframe (drivers side)" can someone on here please ID the correct name of the part/s i need so i can tell emperor tuning Edited September 16, 2016 by wilo Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 16, 2016 Share Posted September 16, 2016 just messaged the mechanic asking what arm i needed and he replied this ..... "It's front lower arm ball joint on hub end and Bush on inner where it goes in to subframe (drivers side)" can someone on here please ID the correct name of the part/s i need so i can tell emperor tuning Try Alex or one of the Zed shed crew for a definitive answer hopefully. Link to Buster: http://www.350z-uk.com/user/11228-buster/ Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted September 16, 2016 Share Posted September 16, 2016 Sounds like - http://cougarstore.co.uk/index.php?main_page=product_info&cPath=1_9&products_id=217 Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
GMballistic Posted September 16, 2016 Share Posted September 16, 2016 Sounds like - http://cougarstore.c...products_id=217 Sent from my iPad using Tapatalk I was think that but wilo did post this... ...And the mech said it needs a new OSF bottom arm ( one under banana arm) Lower link or control arm?! ..not sure what it's called other than maybe one of those two names. Part number 11 below I think is what the mechanic is referring to. Quote Link to comment Share on other sites More sharing options...
wilo Posted September 16, 2016 Author Share Posted September 16, 2016 Sounds like - http://cougarstore.c...products_id=217 Sent from my iPad using Tapatalk I was think that but wilo did post this... ...And the mech said it needs a new OSF bottom arm ( one under banana arm) Lower link or control arm?! ..not sure what it's called other than maybe one of those two names. Part number 11 below I think is what the mechanic is referring to. just sent the mech a pic off cougar store to see if its the correct arm or not . wish id seen what he's referring to now to make ID easier Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 16, 2016 Share Posted September 16, 2016 just messaged the mechanic asking what arm i needed and he replied this ..... "It's front lower arm ball joint on hub end and Bush on inner where it goes in to subframe (drivers side)" can someone on here please ID the correct name of the part/s i need so i can tell emperor tuning That will be the compression rod going by your mechanic's description. Quote Link to comment Share on other sites More sharing options...
wilo Posted September 16, 2016 Author Share Posted September 16, 2016 just messaged the mechanic asking what arm i needed and he replied this ..... "It's front lower arm ball joint on hub end and Bush on inner where it goes in to subframe (drivers side)" can someone on here please ID the correct name of the part/s i need so i can tell emperor tuning That will be the compression rod going by your mechanic's description. replied to PM mate Quote Link to comment Share on other sites More sharing options...
Jon T Posted September 17, 2016 Share Posted September 17, 2016 Wilo that will be the banana/compresion arm. I only have Passenger side sadly. I have rear hubs/bearings. Quote Link to comment Share on other sites More sharing options...
