Justthejedi Posted September 12, 2016 Share Posted September 12, 2016 When i plug my phone in to listen to music it's only playing through the right speakers. I've tried x2 leads and it's the same so not the leads. Can the socket be replaced without having to replace the whole stereo system?....anybody had the same problem? 1 Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted September 12, 2016 Share Posted September 12, 2016 I don't know the 370 but what leads are you using? Does it have 3 or 2 channel connections on the plug? I think Apple leads used to use what would traditionally be the mic channel for one of the L/R channels on their 3 channel phono leads. I'f presume he zed would use the traditional channel set up and wouldn't have a proprietary lead. Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted September 12, 2016 Author Share Posted September 12, 2016 It's just a normal jack lead, 1 channel like the apple lead. Quote Link to comment Share on other sites More sharing options...
Randy_Baton Posted September 12, 2016 Share Posted September 12, 2016 (edited) 1 channel? well that's your problem. Presume that was a typo. If you've only got one channel then the output would be mono. How many black line does it have on the Jack? 1 line - mono output (1 channel) + ground 2 lines - stereo output (2 channel L/R) + ground 3 lines - stereo output + microphone input (2 channel L/R + mono mic) + ground Either side of each line is a separate electrical contact. Although looking at below if you were using a mono lead I think it would only play through the left. Edited September 12, 2016 by Randy_Baton 3 Quote Link to comment Share on other sites More sharing options...
chirag1988 Posted September 12, 2016 Share Posted September 12, 2016 1 channel? well that's your problem. Presume that was a typo. If you've only got one channel then the output would be mono. How many black line does it have on the Jack? 1 line - mono output (1 channel) + ground 2 lines - stereo output (2 channel L/R) + ground 3 lines - stereo output + microphone input (2 channel L/R + mono mic) + ground Either side of each line is a separate electrical contact. Although looking at below if you were using a mono lead I think it would only play through the left. Handy to know, I didn't know the lines meant different types of jack leads! Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted September 12, 2016 Author Share Posted September 12, 2016 1 channel? well that's your problem. Presume that was a typo. If you've only got one channel then the output would be mono. How many black line does it have on the Jack? 1 line - mono output (1 channel) + ground 2 lines - stereo output (2 channel L/R) + ground 3 lines - stereo output + microphone input (2 channel L/R + mono mic) + ground Either side of each line is a separate electrical contact. Although looking at below if you were using a mono lead I think it would only play through the left. thanks for this info, I didn't know about the separate lines, just checked mine and it's got x2 rings round it. It was working perfectly but now only works through the left Speakers if you hold the lead at an angle. Think I will give nissan a call and ask if they do replacement sockets. Quote Link to comment Share on other sites More sharing options...
richparks Posted February 8, 2017 Share Posted February 8, 2017 I have a similar problem in my 2009, i've tried 3 aux cables and none of them work at all - no left or right, the connection feels quite loose, any one replaced the aux port? Quote Link to comment Share on other sites More sharing options...
Justthejedi Posted February 8, 2017 Author Share Posted February 8, 2017 I think the replacement socket is around £85 from Nissan plus fitting. I haven't got round to replacing mine yet. Quote Link to comment Share on other sites More sharing options...
richparks Posted February 8, 2017 Share Posted February 8, 2017 I think the replacement socket is around £85 from Nissan plus fitting. I haven't got round to replacing mine yet. Struggling to speak to anyone at Nissan that can give me an answer, been put through to about 5 different customer service lines and no one has a clue. Quote Link to comment Share on other sites More sharing options...
Strudul Posted February 8, 2017 Share Posted February 8, 2017 (edited) 1 channel? well that's your problem. Presume that was a typo. If you've only got one channel then the output would be mono. How many black line does it have on the Jack? 1 line - mono output (1 channel) + ground 2 lines - stereo output (2 channel L/R) + ground 3 lines - stereo output + microphone input (2 channel L/R + mono mic) + ground Either side of each line is a separate electrical contact. Although looking at below if you were using a mono lead I think it would only play through the left. You missed off the 5-pole TRRRS. Edited February 8, 2017 by Strudul Quote Link to comment Share on other sites More sharing options...
