New lines, fluid, discs and pads
Miller350z
I'm going to be fitting the above tonight and am a little unsure how to go about it. I've got a vacuum brake bleeder and I was going to...
Remove a decent amount of fluid from the master cylinder and replace with new.
Remove one line, replace with a new one, attach my vacuum and pull the fluid threw until it's just fresh fluid coming through.
I will be doing one line at a time but on the vacuum instructions it says start with the line closest to the master cylinder and it also says that on a few other reviews I've read. However I've read on here people bleed the brakes starting with the furthest away. Is this only if bleeding and if changing lines do the closest?
Any advice or a guide would be good thanks
Sent from my SM-G930F using Tapatalk
