Bockaaarck Posted September 2, 2016 Share Posted September 2, 2016 (edited) Ok guys, so just a quick question regards the throttle control relay / actuator. I have a 2003 JDM Zed which has been throwing up the old P1122 error code. So I know that's related to the throttle and likely candidates are the throttle relay / actuator. Bearing in mind my Zed is JDM, I'm guessing I cannot replace the relay with a UK spec relay? I assume I will have to get a JDM spec relay / actuator as there may be different 'electrical standards' (can't think of a better way of phrasing it) between JDM and UK. Any thoughts / suggestions / advice? Edited September 2, 2016 by Bockaaarck Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 2, 2016 Share Posted September 2, 2016 A relay is a relay. You will get all the numbers off the old relay. However not sure what relay you are referring to. If you are referring to the TPS, it is fitted to the pedal. Quote Link to comment Share on other sites More sharing options...
Bockaaarck Posted September 2, 2016 Author Share Posted September 2, 2016 (edited) Hi Alex, on occasion when I start the car, and occasionally when I'm driving. I get the ABS TCS and Slip! lights flash up and remain on. D Doesn't seem to be any issue with the brakes / braking as that has been well checked. Doesn't appear to be an issue with the traction control either. I have noticed when I start the car that the idle is occassionally high, but then drops. From the digging I've done on the code and the info above, throttle is probably most likely candidate. It sounds like the issue might be the throttle control motor relay or position sensor? You'll have to forgive my lack of mechanical knowledge NB: the sensor on the pedal has also been replaced and the error persisted Edited September 2, 2016 by Bockaaarck Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted September 2, 2016 Share Posted September 2, 2016 I would still be looking at the electronic throttle control actuator. Might be a plan to get the car on Consult to remove the guesswork. Quote Link to comment Share on other sites More sharing options...
Bockaaarck Posted September 2, 2016 Author Share Posted September 2, 2016 Thanks Alex, that's really helpful Quote Link to comment Share on other sites More sharing options...
