where do these go
wilo
I've got the same set but in purple! All the long ones are for the plenum. I than just worked my way around the bay removing bolts and placing them next to the new ones to find out which size to use. There should be a rough diagram on the ebay page to show the areas the bolts are used.
You can use this pic to help:
http://i.ebayimg.com...EZG/s-l1600.jpg
Edited by GizmoGold
cheers mate ill take a look when i get home
Remember to put the plenum bolts back in the right order, search on the forum for the order I think ZManAlex has posted it up a couple of times in the past.
thanks im going to leave the plenum ones till i get my plenum spacer.
Yes,paddy did the group buy in 2014.
Not sure how much help it will be but here are the group buys he was running....
#1: http://www.350z-uk.com/topic/80659-engine-bay-bolts-group-buy-1-now-closed/
#2: http://www.350z-uk.com/topic/82830-engine-bay-bolts-group-buy-2-now-closed/
#3: http://www.350z-uk.com/topic/94243-engine-bay-bolts-group-buy-3-closed/
Lot's of pictures in there though so hopefully will help you out wilo. :thumbs:
yep that's great ..cheers GM for the links .not the same but a very similar kit so will help locating where things go
Remember that the plenum spacer bolts are longer by the thickness of the spacer, so your coloured ones may be to short. ;)
it stated on the ebay page that it comes with longer bolts for a 5/16 plenum spacer but i think i get bolts with the one im ordering off here ( cant remember the company lol ) edit just checked its a motordyne from Adrian Edited by wilo
