Fluke Posted August 31, 2016 Posted August 31, 2016 As per title, my car (Its a 2003 DE UpRev) threw a P1283 after having the Berk HFC's fitted to my Milltek system. This was after having a remap at TDI North last week. If I swap my HFC's back to my factory standard cats and clear the code it doesn't return until I put the Berk HFC's back on, and will return after a few miles even after multiple resets. My understanding is that the code is a lean shift on bank 2 sensor 1 and this is pre-cat. Can anyone tell me how to solve the problem? Quote
Fluke Posted August 31, 2016 Author Posted August 31, 2016 Its the second time I have been back to them and it only seems to happen with the Berk's fitted. Has anyone else had the same problem? Quote
ZMANALEX Posted August 31, 2016 Posted August 31, 2016 Phone TDI and get them to look at it? Or swop out the sensor. Quote
Tricky-Ricky Posted August 31, 2016 Posted August 31, 2016 Why didn't they simply turn off the cat O2 sensors during the remap....its a little worrying that they don't seem to know to do this when fitting decats or hyflow cats., sensors 1-bank 1 and 2 is the main O2 sensors, sensors 2- bank 1 and 2 are the cat monitors. Quote
ZMANALEX Posted August 31, 2016 Posted August 31, 2016 You can't turn off the sensors for the OPs issue as the code relates to front sensors. However the rear sensors as you rightly mention can be turned off as they serve little significant purpose. Quote
Tricky-Ricky Posted August 31, 2016 Posted August 31, 2016 Couldn't find the code, so presumed it was the usual cat sensors giving a spurious reading. Quote
Stutopia Posted August 31, 2016 Posted August 31, 2016 Given the cats have been changed, is there a chance this might be a genuine air leak? Quote
Mark@Abbey m/s Posted August 31, 2016 Posted August 31, 2016 old slow sensor or air leak is my guess? did you get the berks fitted? Quote
GMballistic Posted August 31, 2016 Posted August 31, 2016 Its the second time I have been back to them and it only seems to happen with the Berk's fitted. Has anyone else had the same problem? Nope. Ran Berks HFC's with an Invidia Gemini system on my old 03' Zed that Horsham Developments remapped (UpRev) and never had an issue. Good luck. Quote
Fluke Posted September 1, 2016 Author Posted September 1, 2016 Would a dodgy front sensor work with the factory fitted cats and not the Berks? Would a leak down stream of them throw up the code? I replaced the both rear O2 sensors when the Berks were fitted as they were falling apart when they were taken out during the factory fitted cat removal. The car runs fine and if I refit the factory cats and clear the code, it doesn't return. Would an air leak on the Berks HFC's cause a P1283 code? Quote
Tricky-Ricky Posted September 1, 2016 Posted September 1, 2016 Its possible for a downstream air leak to mess with the front sensor reading due to reversion, but only likely if the leak is at the junction of the manifold and the cat, as i said i don't have that code on my chart so was nor sure which sensor or rich/lean, but if its showing a lambda code for either then its obviously out of range. Quote
Fluke Posted September 1, 2016 Author Posted September 1, 2016 The Berks seem to fit fine, and I cant detect anything blowing. I was wondering if a bad seal around the o2 sensor going into the HFC would cause an issue? I know that the thread on the HFC bung had to be chased when it was fitted. Quote
Tricky-Ricky Posted September 1, 2016 Posted September 1, 2016 i would say it would have to be quite a leak to affect the reading. Quote
Fluke Posted September 2, 2016 Author Posted September 2, 2016 Alex, do you have a sensor available? Quote
ZMANALEX Posted September 2, 2016 Posted September 2, 2016 Alex, do you have a sensor available? Yes brand new and pre owned are in stock. Drop me a PM if I can help further. Alex. Quote
